Page 2 of 2 FirstFirst 12
Results 41 to 75 of 75
Thread: Exhaust Nirvana
  1. #41
    Active Member Three Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Quote Originally Posted by Fresh.S4 View Post
    Nah I'm fine with it for now. I don't go wot enough that it bothers me. I mainly just want to improve the low rpm cruising around town burble
    shouldn't have deleted the baby res.
  2. #42
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    @OP At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul.
    Quote Originally Posted by brs2c View Post
    What you say is true, but only to a degree. Exhaust provides gains if it:
    A) Is a shorter and/or straighter route to exit
    B) Has less obstructions (crush bends or cats etc)
    C) Provides an a better diameter of piping to support a particular power level
    D) Does a better job at smoothing exhaust pulses
    AWE has demonstrated a 9 horsepower gain on a STOCK vehicle. I would venture to guess that the gains from the AWE are from the x-pipe (D), and maybe a little straighter shots through the mufflers (B). However, this is on a stock vehicle with 2.25" piping, which will support a max flow of 416 bhp. However, something making bigger power, like an Dual Pulley Ultracharged car on 104 octane, making 541 bhp is going to see significantly more of an increase, than what was seen from the stock 333 bhp.
    soild points. can you elaborate on the bold? i'm curious.
    stock exhaust is 55mm actually, which is 2.165"
    CURRENT 2013 S4 // ESTORIL BLUE // 6MT // RS BUMPER // GIAC STG 2+ 3.2 PR // FORGE CC // AWE TOURING // ROC EURO // KW HAS // BC FORGED HCA381-F // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + tints, sports diff, j-codes, Akebono pads, SS clutch line...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
  3. #43
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by KRp220 View Post
    Horsepower is a function of how much air can flow through the engine, and as a result, the exhaust. A certain cross sectional area of exhaust piping can allow a certain amount of air to go through it. Once you get over 400HP, (as stated) the 2.25" piping literally cannot flow enough air through it, and thus becomes a bottleneck.
    Check out this video
    https://youtu.be/_PVXvHkr-Vs
  4. #44
    Mar 09 2018
    Southern Wisconsin
    Indeed. I am in abject sorrow over my insolence.
    Thank you for the correction. You are a god among Audizine members and I bow before the might of your wisdom.
    Sconnie
  5. #45
    Aug 23 2011
    NH
    Quote Originally Posted by Morritse View Post
    2.5 or 2.25? BRS said 2.25 and you're saying 2.5. it just seems odd that stage 2 has been around for years (400+ hp) and no one has come up with an exhuast greater than 2.5"
    it seems like a very blanket statement thats all
    will check you the youtube video after work. thanks!
  6. #46
    Aug 23 2011
    NH
    Quote Originally Posted by SconnieRoadie View Post
    Sconnie
    do you always talk like you're from ancient Greece?
    its a line from the movie Billy Madison, so it s a joke.
  7. #47
    May 08 2018
    Berkeley, CA
    Hey, I edited my post, you must have responded before I submitted. It is indeed 2.25 inch piping!
  8. #48
    May 08 2018
    Berkeley, CA
    He lives in "southern Wisconsin" dude, give the pour soul a break.
  9. #49
    Jun 13 2017
    Philadelphia
    g35 coupe? So the engine in like every mid range nissan performance car...
    VQs don't sound good, definitely not better than s4 with decent setups
    That's incorrect. Stock g sounds better than stock s4, most would agree.
    Sent from my ONEPLUS A3000 using Audizine mobile app
  10. #50
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by mercedesinfarct View Post
    Lol why are you comparing stock vs stock? Doesn't this further prove my point? Audi obviously designed the s4 to be a luxurious quiet car. Stock s4 doesn't sound like anything on the s4. That was the intent. We are comparing VQ to 3.0TFSI. Not the sound a VQ makes in a stock g35 vs the sound a 3.0t makes in a stock s4.
  11. #51
    Established Member Three Rings MSq5's Avatar
    Feb 14 2017
    Gulfport, MS
    Sconnie
    Perhaps the point being made, lost in your sarcastic response, is that many of us here are over 400 crank horsepower and can obtain real power gains from a more free flowing exhaust. In my case with a Q5, I have an even quieter exhaust than the S4. Nonetheless it seems to flow pretty well up to now, but has been maxed out with me at about 420 crank hp. I am at a point where a better flowing exhaust will show positive dyno gains. But, I don't want it to drone. A more free flowing exhaust along with improved heat exchanger cooling and a "dual pulley" (ratio above 3:1) are in the works. It is a false assumption to conclude that those seeking a better exhaust are just chasing sound.
    2017 Q5 3.0T S-Line | Brilliant Black | EPL Stage 2 93 octane tune | JHM 179mm crank pulley | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose
  12. #52
    Mar 03 2010
    Pitsburgh, PA
    I kind of love the stock S4 exhaust, especially with the soundaktor turned off. I think stage 2 wakes up the exhaust some and most people have dumped the stock by then. It's not loud inside the car but I still enjoy the sounds that it makes. To me it's still a dampened but meaningful euro sound.
  13. #53
    Jan 03 2018
    South Carolina
    I installed the Becker test pipes this week, I didn't think it would have made that big of a difference in the sound of the stock exhaust(empty can). I now need that gone, without changing the performance gains from deleting the CATs. IDEAS?
    Oolong Grey A7 | EPL DP 91-104 tune| Merc Hx| 57/189mm| Cat delete| Magnaflow x-pipe| ported SC
  14. #54
    Feb 17 2018
    Nyack NY
    Sountaktor is stupid. For the love of god I hope companies figure out how stupid video game engine sound is in a hurry. In my f80 m3 the active sound literally started to give me a headache after long drives in Sport+ mode. Valved exhausts are the best of both worlds. Also, my resonated Milltek sounds amazing - I slightly preferred the overall output of the non-res but it was definitely a little droney and I have a long commute.
    You think exhausts are expensive for these cars, the "M" tax on the f80 stuff was staggering.
  15. #55
    Established Member Two Rings klquattro's Avatar
    Jan 14 2016
    North NJ
    Ive got the AWE track exhaust, stock DPs on mine. Yes its probably way louder than necessary in all facets of driving and the drone between 2.5k-2.9k RPMs is annoying to the point I wish I would've gotten the touring, but boy oh boy whenever I get on it the smile doesn't leave my face. Then I sometimes get a crackling/backfiring type sound when I let off the gas in gear and it makes me all giddy.
    I definitely didn't get that sound with the stock exhaust and the soundaktor is just Audi's way of saying, we know we made a relatively quiet luxury sports car so heres some fake noises to improve your mood. Its not like it effects the exterior volume at all.
    '15 S4 - Mythos Black - 034 Stage 1 - AWE Track Exhaust
  16. #56
    Established Member Three Rings DufraineMK6's Avatar
    Jan 09 2017
    2014 Monsoon S4 6MT
    Northern VA
    I'll just leave this right here...
    I read all the exhaust note threads and note that people are spending literally thousands of dollars on aftermarket mods. I watch the videos and listen to the modded exhausts. Then I get into my stock exhaust S4 and think to myself, those aftermarket exhausts sound like s*** compared to OEM. Full of rasp, ugly drone, and harsh tone. Maybe just turn up the volume on your soundaktor? If you are dumping large on your exhaust, I bet you have a vagcom.
    My position is that tuning an exhaust is no different than an amplifier/speaker hooked up to it, when all is considered. Well, actually, it is different, it cost you thousands. A vagcom is what, $100?
    Just sayin'.
    Sconnie
    Are you even a car guy or is this really your wife’s car.
    14 S4 6MT - Sport Diff / H&R Street Performance Coilovers / CW Pro Stage 2 (6-1) 93/E85 Mix / JHM 179mm Crank Pulley (1300mm 7 Rib Belt) / ECS Tuning Flush Kit 10mm F & 12.5mm R / 034 Motorsports Intake Tube W/ AFE Pro Dry Filter / USP Stainless Steel Clutch Line / AWE Touring 102mm Stock Downpipes / Eurocode Trans Mount
  17. #57
    Jun 13 2017
    Philadelphia
    Quote Originally Posted by DufraineMK6 View Post
    so to be a car guy is to only have one opinion. got it.
  18. #58
    Jan 09 2017
    2014 Monsoon S4 6MT
    Northern VA
    You said all these aftermarket exhaust sound like shit compared to OEM. RASPY etc. the oem exhaust is raspy. Then you said “tuning an exhaust” is no different than adding a speaker or amplifier. Other than 1000 dollars. Lmao.
    Your topic was bullshit. Your thread was bullshit. You can have whatever opinion you want. No one here knows what that is. No one cares. If you have any sort of car. Please trade it in for a horse. Donkey. Whatever.
  19. #59
    Feb 14 2017
    Gulfport, MS
    I think you nailed it. He's a Prius guy, driving around listening to Ferrari engine sounds on a CD playing on his car stereo. Thinks that's the solution for a good sounding exhaust.
  20. #60
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
  21. #61
    Established Member Two Rings kevinz's Avatar
    Aug 17 2016
    2015 S4::2010 Q7 3.6
    this thread is cancer
    2015 S4 6MT Sepang
  22. #62
    Aug 25 2013
    florida
    i would agree with both cases though, both the vq & 3.0tfsi acoustically sounds better stock, most aftermarket exhausts for either engine is either too loud at high rpms or rasps too much.
    actually i would be very content on a 12valve vr6 file for my soundaktor. i would blast the interior volume on 11/10ths and then wire up powerhorns behind my grill for the full wookie experience
    2014 sfeux p+ 6mt bo nav w/o sd
  23. #63
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Quote Originally Posted by kevinz View Post
    This. Hoping none of you reproduced.
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
  24. #64
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by Oloung1 View Post
    $90 x pipe and gutted stock cats. No rasp. No drone. Cheap as hell. How do you think it sounds??
    https://youtu.be/ExubD7CckSE
  25. #65
    Dec 06 2017
    Marietta, GA
    Which X-Pipe? Actually does have a "stock+" note it would seem. Would like to hear it through the gears.
  26. #66
    Mar 03 2010
    Pitsburgh, PA
    Yah. Sounds good!
    Last edited by administerturbo; 07-09-2018 at 07:50 AM. Reason: Meant to quote another comment
  27. #67
    Mar 03 2010
    Pitsburgh, PA
    I do like that!
  28. #68
    Veteran Member Three Rings Hightekflytech's Avatar
    Sep 24 2013
    I.E. Cali
    Best sounding cheap exhaust IMO
  29. #69
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by Impreziv View Post
    https://www.amazon.com/Magnaflow-113.../dp/B000XQQ09Q
  30. #70
    May 08 2018
    Berkeley, CA
  31. #71
    Active Member Two Rings SebR's Avatar
    Apr 20 2017
    Ontario
    Sorry just to clarify, this is just gutted cats and replacing the baby res with the res magnaflow x-pipe and everything else stock?
    Monsoon B8 s4
  32. #72
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by SebR View Post
    Center resonator is also deleted!
  33. #73
    Established Member Three Rings brs2c's Avatar
    Apr 26 2017
    Nashville, TN
    Morritse- are you certain your stock cats are gutted?
    2013 S4, Monsoon Grey, DSG, B&O, Sport Diff, Nappa || Custom 3.5" Velocity Stack Intake, EPL Stage 2+, Fluidampr 183mm CP, EPL TCU, AMS Alpha Cooler || VMR V804's (19x9.5 et45), ECS 2-piece Rotors, Stainless Lines, 034 SB, 034 inserts.
  34. #74
    May 08 2018
    Berkeley, CA
    No
  35. #75
    Active Member Two Rings 4DOORFUN's Avatar
    Jul 22 2016
    Glen Ellyn, IL
    Quote Originally Posted by B8F80 View Post
    Yup. Even Ford figured it out. The new Mustang GT exhaust design is a work of art and it's all controlled by the driver. The problem is that 99% of Audi owners wouldn't care about variable exhaust. Tons of Mustang owners want that so Ford gave it to them. We represent a small fraction of Audi S4 owners.
    2016 S4 DSG | Florett Silver | Black Optic | Tech | Nappa Leather | Sport Diff | Michelin's AS 3+
