Results 1 to 6 of 6
    Established Member Two Rings TMeschke's Avatar
    Sep 20 2016
    2003 Audi A4 Quattro 1.8T 5MT
    Minneapolis, MN
    WTB: Turbo Cooling Lines, Stage 2 Clutch, and CTS FMIC
    Hello All,
    I知 currently in the process of dropping a GT2860R in my 2003 A4 Quattro 5MT. A couple of the things I still need to get are some good turbo cooling lines (coolant and oil), and a clutch that can hold the additional power. Also looking for a CTS FMIC, if anyone happens to have one. I知 also planning to run E85, so I値l probably be needing a new fuel pump and possibly a returning fuel line setup.
    Feel free to let me know what you have available, including anything else you think might interest me
    2003 Audi A4 1.8 Quattro 5MT - Brembo 17Z Front Calipers, 2.0 TFSI Coilpacks, 034 Test Pipe, B&B Sport Exhaust, VMR V701 ET35, H&R Sport Springs, Some Shitty ECU Tune
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Do you need any injectors by any chance? I have some Bosch 550痴 for sale.
    2005 1.8T Quattro
    GTRS Eliminator Turbo / Motoza BT 1000cc injector tune / IE intake manifold / TT225 MAF w/ 42DD TT225/Carbonio CF intake / BB Stealth cat-back exhaust w/ ATP 3" test pipe / APR cast DV / CTS Turbo FMIC / JHM short shifter + linkages / 034 street density motor/trans mounts, upper(adjustable) & lower control arms / Bilstein PSS9 coilovers / Hotchkis S4 rear sway bar w/ 034 end links
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '18 S5 SB // '05 MV Agusta F4-1000
    Mo County, MD
    Items for Sale
    I have the ER competition FMIC kit, inlcuding crash bar, coming to the classifieds later today
    Current: '18 S5 | SportBack | Prestige
    Previous: S4 | Stage ++ | PLM
    Sep 20 2016
    Minneapolis, MN
    Quote Originally Posted by BumblebVR6 View Post
    I do also need injectors, but I値l probably go with 750s if I知 gonna run E85.
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by TMeschke View Post
    I just realized that you said you were planning on running e85 :) You may actually want to use 1000cc unless you have return fuel system.
    2005 1.8T Quattro
    Sep 20 2016
    Minneapolis, MN
    Ideally I値l be running a returning fuel setup. So if anyone has an IE fuel rail and some lines for a good price, HMU
