Big update:
So the paint on the bottom of my fenders has started flaking, this is thanks to the budget bodywork I had done when I originally rebuilt the car. I looked around for replacement fender in monsoon grey with no luck. Having a bodyshop fix the fenders would cost a good coin, and snowball into me doing the hood and then having the front wrapped in clear bra all of which isn't quite in the budget right now. The solution was to fix it myself.
Here's the flaking fenders, they were really becoming an eyesore and I wasn't even motivated to detail the car because of it
After chipping away the loose paint and bondo
Some sanding
After more sanding I did a thin layer of filler
Untitled by
Ayrton@Drive19Photography, on Flickr
And some more work
base coat
clear coat- the clear I got from touch up direct was unimpressive, it didn't lay very flat but as you'll see next that was the least of my issues
When the front of my car was originally resprayed the paint wasn't a perfect match, this paint was a closer match and as a result there was a bit of an issue.
Shit.
Now i could either leave it like this, looking worse than when I started or figure out how to fix it. I chose the latter! Remasked for some blending
After the blending, the lines left over are over spray lines that were later wetsanded
After wetsanding and polishing. is it perfect? Certainly not, but it looks better than the chipping paint!
The driver's side was going well, I'd learned a lot from the first fender and gotten the blend right first go. Alas, I didn't quite lay on enough clear coat and this happened during wetsanding
Time to remask and repaint lol
Everything put back together, wetsanded and polished
I'm pretty happy with how it turned out! Again not perfect, but my friends who thought I was insane for attempting this were impressed with the results haha.
I also picked up this set of 90mm AWE Black Diamond exhaust tips from another AZ member. They need a good polish but should clean up nicely; they'll be going on my S4 exhaust that I've been waiting to install.
Next up is the new shift selector which I finally installed
As my technician friend and I hypothesized, with the test pipe/cat removed, there is enough room to replace the shift selector.
Now I didn't take many pictures because this job kinda sucked, I started late because I spend most of the day getting ready for a work trip I was leaving for the following day, and ended up finishing this project around 4am. So after all that my shifter issues should be fixed right? NOPE! Absolutely no improvement, if anything shifting is
slightly worse lol. At that point I was honestly just happy to have the car back together for my drive to Cleveland where I was for work all week. The silver lining to all this is that the car is still drivable, it made the trip to Cleveland without a hiccup though fuel economy was rough (22ish) although my heavy foot was probably to blame.
Going to confirm this week with a master-tech at work, but at this stage we're thinking some sort of internal failure occurred. I'm thinking this means a new transmission which drives me up the wall because I had to replace the trans in my old B5 (that car inexplicably shredded 4th gear). For a car that isn't beat on, and is well maintained I'm gutted but such is life. This past week I went through a ton of emotions, the past few times I got in the car I secretly hoped someone would smash into it and write it off (again) so I could find a manual B9 and start fresh lol. But I know once it's fixed I'll be happy again so I'll more than likely get another transmission and have the dealership install it. I'll update more as I know more
Once I get the transmission sorted I'll have the wheels refinished and I'll do a multi-stage paint correction on the car and re-ceramic coat it. Doing the exhaust is also on the list, maybe I'll do an RSNAV upgrade if we're lucky.
