So during this quarantine the itch to work on the car has been strong
However, due to uncertainty of employment status or when I'll even go back to work, blowing money on the car isn't exactly the most financially responsible choice. That said I have a list of things I can do without spending loads of money so I figured now would be the perfect time to tackle it, and got started this weekend.
Since I finished the car, there has been an unsightly gap between the fender and bumper on the passenger side. No one has ever commented on it, so I suppose it's more noticeable to me than everyone else, nevertheless I figured it was time to sort it out.
Here's the gap, fender pushing in a little too much at bottom corner
from the side, it also sits a little lower towards the back
After a bunch of twisting and shimming the bracket the goes from the frame rail to the fender I got the top view nice and flush
However, the side profile is still off by about the same amount
I took everything back apart, removed the headlight and kept messing with things trying to perfect the fitment but ultimately discovered that the mangled upper rail that we pulled out during the initial rebuild is still a little lower than that of the driver side. This issue is slight because the fender fits properly, but the part that the core support attaches to must slightly be lower. To fix this, the entire front clip would need to come apart, I'd have to lift the rail, and put everything back together, multiple times over until it was perfect. That would be at least an entire days work assuming no issues, so I'm not going to bother for a defect no-one notices on a 7 year old car. It's 50% better now than before though so I'll take that!
While I was in there I noticed my sound box delete was looking a little rough, the stopper I hose clamped to the charge pipe was cracking after ~15k miles over the course of a year of use.
That cracking didn't go through to the inside so it probably would've lasted quite a while longer, but I had a few fresh ones laying around so I tossed one on. Maybe I'll buy a charge pipe at some point, but these are cheap and easy to replace so it's not a priority as of yet. Maybe next time I'll wrap some foil tape around it to deflect heat
A couple random pics for you guys
Next might be pulling the rear bumper to fix the parking sensor that's pushed in (previous owner seemed to like backing into stuff
) Might also pop the valence off and and plastidip it black to match the rest of the car. Here's a little "Quarantine Checklist" I made, my challenge will be to see how much I can actually accomplish haha.
- Improve front bumper fitment X
-Fix PDC sensor and dip rear valence
-Interior Detail X
-Exterior Detail X
-Refurb fog lights X
-Lightly Smoke tail lights
-Accessory belt replacement X
Stay tuned!
