Results 1 to 5 of 5
    Jun 04 2012
    Greenville NC
    AC not working after Timing Chain rebuild
    After I pulled the engine and transmission to replace and update the timing components, and basically rebuild the whole engine, my AC hasnít worked since. Refrigerant and all fluids are correct, but it still doesnít blow cold air.
    Anyone else run into this problem? Advice? Thanks for your feedback!
    - - - Updated - - -
    Forgot this: car is a 2004 S4, 6MT
    May 20 2010
    Did you reconnect the condenser refrigerant pressure switch? It may have gone bad regardless. Or if you had removed the fans, one may not be working.
    2016 A6 TDI Prestige - stock
    2003 allroad 6MT - STUKLR Stage 1, Hotchkis sway bars, RS4 engine mounts, Apikol rear diff mounts
    Jan 17 2018
    2016 Triumph Thruxton
    San Tan Valley, AZ
    is the ECON light on? if it is can you turn it off? if you cant turn it off check the fuse for it.
    2005 Audi B6 S4 - Brilliant Red with Black Recaros and 6MT.
    RS4 Guides, chains, tensioners, JHM Cam Adjusters, JHM intake spacers, JHM 6 rib lightweight pulley kit, SPEC single mass flywheel, new stock clutch, new clutch slave cylinder, etc......
    Established Member Two Rings Mike50design's Avatar
    Feb 17 2017
    Mission/BC/Canada
    Did you replace the drier while you were at it?
    2007 Audi S4 (DTM)
    Senior Member Three Rings a4lownslow's Avatar
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Check HVAC module using vagcom for fault codes. Then go to your measuring values and check shutoff criteria for the compressor. From there you should hook up a manifold gauge and check high and low pressure.
