Results 1 to 6 of 6
    Established Member Two Rings Robdukes's Avatar
    Dec 11 2014
    01 Audi A4 2.8 Quattro
    Mount Cobb, PA
    If you have stuck caliper carrier bolts
    Today is brake day. Replacing my rotors and pads on the front with ECS slotted rotors and Stop tech street pads. I heard the caliper carrier bolts are tough to get off. Didn't expect this though. Brand new crescent brand socket wrench is slipping now after whacking it many times with the mallet. Broke a 1/2 inch to 3/8 adapter from just brute force as I torqued on this thing. It's crazy.
    I hit it 3 times with PB Blaster. Smacked it with hammers, used extender arms. It's like it's welded on there.
    Finally got it off and there's a trick to it. You need a second person sitting in the car holding the wheel over as far as it will go. If you do it yourself, as soon as you let go of the wheel you lose the tiny bit extra you need to be able to fit a longer breaker extender on. Use a 1/2 drive 21mm on a breaker bar with a pipe on back to extend it while someone holds the wheel as far as possible and you can get outside the fender for max torque.
    On a second note. The Stop tech street pads had kind of crappy clips on the inside pad to hold it to the caliper. Reused the original ones instead because the stoptechs kept popping off as I tried to fit it into caliper.
    Dec 11 2014
    Mount Cobb, PA
    Had some clunking today that was never present before. Sounds like these pads are clunking around when hitting dips in the road.
    Another curious thing. When I got home and inspected the new pads they look as though they are unevenly touching the rotor. I'll attach a pic of each side. Not sure if this is normal or not.
    May 12 2017
    needs cleaned
    Land of Archaic Anachronisms
    i did not have the trouble you did getting the bolts off on my 2011 A5 like you did...
    ...hit them with PB Blaster & let sit for an hour....
    also, i used a V thin film of high temp RTV on the non-piston side to 'glue' the brake pad to the caliper....
    Billy
    2011 A5 2.0T Old Man Project
    1983 Porsche 944 (Modified)
    1971 Moto Guzzi Elderodo
    Avatar Chart
    Aug 23 2017
    Staten Island
    Quote Originally Posted by wkhanna View Post
    Oh man, I had to take a brake from watching the mechanic struggle to get the pin out so he could replace the pads. That was a work out
    Dec 11 2014
    Mount Cobb, PA
    Never had this kind of trouble. Even on old cars that were all rusty. It was like they used the biggest gnarliest impact gun at the factory to put these on. My father in law was like "You're never gonna get that, you need to take it to a shop, I don't know why you're killing yourself, it's not going to come off".
    Just made me want to prove him wrong. Never give up, where there's a will there's a way.
    May 12 2017
    needs cleaned
    atta boy!
    Billy
    Avatar Chart
