Results 1 to 4 of 4
    Nov 10 2017
    DRC connection removal
    The bolt that connects the rear DRC connects to the strut is stuck. The fronts came off easy. I've tried penetrating oil but no go. The wrench just rounds the soft metal. It's also hard to get a good angle and there isn't much room to work. Any ideas?
    Sent from my SM-G935V using Audizine mobile app
    Senior Member Four Rings ven0m's Avatar
    May 10 2015
    Slovenia
    Try unbolting the strut and laying it down horizontally. That way you get better access with tools. Try an impact gun, if the bolt head still allows it. Otherwise some big pliers, a good grip, squeeze your butt and hope for the best!
    Jeremy Clarkson: "So when you were saying that it wont slide, what you meant was, I cant slide it.
    James May: "Yes."
    Jun 18 2010
    1991 Escort Wagon
    East of Cincinnati
    Judiciously applied C4??
    Old Geezer, formerly known as Stud Muffin
    Nov 10 2017
    I ended up disconnecting farther up the line and capping it there. Nothing would break that damn thing loose.
