Results 1 to 40 of 72
    Veteran Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Best route to eliminate drone and rasp on catless/res delete
    I have gutted stock cats and an 034 resx xpipe. After gutting the cats, the rasp became too much at high RPMs and the drone is annoying.
    Talked to a muffler shop yesterday, he really wasn't sure what to do, as he hasn't seen this situation before. Have any of you had success eliminating these unwanted sounds in similar setups?
    I'm not trying to drop $1,500 on a catback, I think the desired results can be accomplished by splicing in a certain resonator somewhere in the system. Question is, where and which.
    Jul 02 2017
    2012 VW GTI, 2015 Nissan GT-R Premium
    Smyrna, DE
    Where is your x-pipe placed? And just to be clear, what on your exhaust remains OEM?
    Apr 04 2017
    10 S4, 01 S4, 14 328d
    Chicago IL
    I am running a milltek valvesonic catback. In my experience adding the optional center resonator was helpful in mitigating some of the drone. I've also seen guys suggest that the AWE resonated downpipes help cut the drone, so MAYBE there's a trend in keeping as much resonation as possible close to the engine.
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    Quote Originally Posted by GandalfTheIbis View Post
    I think I'm going to swap the x pipe for the resonator... The rasp sucks on my valvesonic.
    Drone I don't mind. That is fixed by changing the opening of the valve rpm. But sounding like a Honda Civic is terrible.
    Do you mind recording a video of your exhaust? I either have a terrible leak that makes my car sound cheap, or I just need to put the resonator back in.
    Sent from my MI MIX using Tapatalk
    Apr 04 2017
    Chicago IL
    Are you catless? I installed hi flow cats and the milltek valvesonic at the same time and there was definitely some rasp... then a couple weeks ago my cats melted so I’m now running test pipes and added the center resonator on the same day. Valve open is very fart can like especially at lower RPM’s like 2400-3200 ish sounds awful with rasp and the valve open. Closing the valve makes it a bit better but still I hate the raspy frequency down low. Driving on the highway light acceleration in 6th or 7th from 85mph makes the worst noise. I usually downshift to 5th and hit it from there just to avoid the noise.
    I have some revving, launching, and in cabin sound clips I can email you of my setup pre-gutting and resonating. Send me a message with your email address if you want those.
    I don’t have anything of the current setup yet but the plan is to record similar clips.
    Dec 19 2010
    North CA
    I'm catless now, but running the x pipe instead of the front resonator/silencer.
    Strangely enough, once the car is warm/hot, the fart can noise goes away... I need to figure out what the heck is happening.
    Apr 04 2017
    Chicago IL
    Quote Originally Posted by miztahsparklez View Post
    My fart can noise improves significantly once the exhaust heats up as well, and someone on the Facebook page echoed that earlier today as well. I think that’s normal.
    And well, it’s the worst under lower rev, partial throttle conditions. Give the car a lot of gas and it usually revs up fast or downshifts and misses the worst of it.
    Jul 02 2017
    Smyrna, DE
    Quote Originally Posted by Morritse View Post
    https://youtu.be/Rm_SUBPx4l4
    Check out my setup, revs and such in the video. Becker test pipes, followed by magnaflow 11385 resonated x-pipe in place of baby resonators. The magnaflow is a hundred bucks. Stock center resonator and stock mufflers. Zero drone.
    Veteran Member Three Rings VNA4's Avatar
    Jun 20 2015
    San Jose
    Quote Originally Posted by SGR View Post
    How loud is it Cruising mode?
    How's the smell.
    Do you have other videos?
    S4 B8.5 2014
    KW H.A.S. / EuroCode ÜSS Adjustable Sway Bar / AWE Touring Diamond Black / 034 Stage 2+ / DP 187mm / APR Stage II Carbon Back Pipe
    20 x 10 et35 StanceWheels SF01 [PowderCoated Diamond Black]
    SOLD
    AUDI A4 B8 Premium Plus Sport:
    CTS k04/ APR k04 File / AWE Quad exhaust / FMIC: TR8
    VIP VRC 13 : 19X9.5 / Tires: 255/35/19 / Solo werks Coilovers / OE S4 Front Brake Upgrade Kit
    Jul 02 2017
    Smyrna, DE
    Quote Originally Posted by VNA4 View Post
    How's the smell.
    Cruising mode is pretty low-key from the outside when you aren’t accelerating, i.e., cruising. You can tell it’s not stock, though, but it is remains fairly under the radar. As for accelerating, see below:
    https://youtu.be/h2S-mfxbeTU
    https://youtu.be/kCMBKtUOl7Y
    If interested, I can get an in cabin cruising video clip tomorrow.
    Jun 20 2015
    San Jose
    How's the smell? I have two kids that's the family ride lol
    S4 B8.5 2014
    SOLD
    Jul 02 2017
    Smyrna, DE
    Whoops, forgot to mention that before. I sometimes notice heavier exhaust smell with my test pipes when, 1) the windows are down, and 2) after a period of heavier acceleration, particularly on the highway. Seems to waft through the vents slightly, then fades away. However, I started noticing this before the test pipes, after I went intake, dual pulley, UC, etc. Just a little more pronounced now under the conditions I mentioned above.
    Jun 20 2015
    San Jose
    Yes please in cabin cruising would be a decision factor to go with ur setup.
    How does JHMs compare to yours btw? 034 recommends this
    https://jhmotorsports.com/products/e...-4-2l-fsi.html
    S4 B8.5 2014
    SOLD
    Jul 02 2017
    Smyrna, DE
    The Becker test pipes are high quality, IMHO. Extremely solid and the TIG welds were very nicely done on mine (again, IMO).
    I haven’t seen JHM’s test pipes physically to compare them, they’ve got a pretty good reputation though. As for their HFCs (if that’s what you were specifically referring to in the link you pasted), I’m sure they are great but I don’t have personal experience with them either. This is also comparing apples and oranges here. I have augmented my test pipes with a resonated x-pipe in place of the baby resonators, not test pipes in front of $1200 high-flow cat downpipes.
    Honestly, if I could do this whole exhaust setup again (with using test pipes), I wouldn’t change a thing. The only thing I’ll be adding is new tips. Love the way it sounds, no drone, has the best of both worlds for a daily driver. Again, IMO.
    Here’s a quick in cabin video I took today (I should note, soundaktor is still enabled).
    https://youtu.be/f8UAMF9ouCs
    May 08 2018
    Berkeley, CA
    Sounds really nice actually. Wish I still had my stock center piece
    Jul 02 2017
    Smyrna, DE
    You could probably find one at a euro car performance shop in their recycle pile. Every time I’m at my shop, there are always stock S4 and/or S5 exhaust systems sitting there from the last guy who got an AWE put on lol.
    Jun 20 2015
    San Jose
    Sounds meaning but smooth !
    S4 B8.5 2014
    SOLD
    Veteran Member Three Rings $nooze's Avatar
    Jan 02 2012
    Has anyone noticed pipe sizing to instigate more drone? I'm somewhat in the same boat as op. I have 3" to an x-pipe then straight back to flowmasters series 40's (on either side, respectively). My drone is cabin based and has that low frequency hum/ vibration within the 2400(ish range when cold; 2600 ish when warmed) to the under side of 3000rpms.
    Im contemplating adding in two vibrant resonators pre x-pipe. As the sounds feels and seems to be coming from mid car within the cabin.
    Does anyone else notice that the drone and sound is only noticeably from inside and not very existent from outside? I've been outside of my car listening through the rpms ranges and not heard the sounds that I hear when driving.
    '11 B8 S4 6mt
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by $nooze View Post
    I'm doing exactly this today, I'll let you know how it works.
    Jan 02 2012
    Great in for videos of cabin and outside if possible :) lol thanks
    '11 B8 S4 6mt
    Nov 28 2015
    Montreal, QC
    best way is to not cheap out with X-pipe and buy an AWE exhaust. proven result.
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Quote Originally Posted by waxxonMTL View Post
    Plus you get the benefit of tips that will pit, resonators that will fail, and a sweet weedwacker noise on occasion. And it only cost you 2k+ for a catback.
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Apr 04 2017
    Chicago IL
    Meh, resonators that fail, exhaust that still sounds raspy and shitty to me once you install test pipes. Multiple thousands of dollars for results that are marginally better at best. Catback systems were designed with stock catalytic converters in place at a time when stage 2 was the most extreme setup.
    All the cat back offerings on the market are antiquated.
    Jul 07 2009
    Socal/IE
    Exhausts are rarely designed for Catless setups because in most states Catless is illegal and 90% of buyers won't be going Catless anyways.
    Apr 04 2017
    Chicago IL
    Quote Originally Posted by tar View Post
    Ok, so maybe calling them antiquated is harsh... but this thread is still regarding a catless setup
    Jul 07 2009
    Socal/IE
    Ya I read that now I thought it was the other thread with almost exact same title that was started a day earlier than this thread.
    But still if you read above your post that I quoted (post 19)you will see i said the exact same thing you did about the awe issues.
    Apr 04 2017
    Chicago IL
    #sameteam
    May 08 2018
    Berkeley, CA
    Hey guys, after doing some research a couple things became apparent to me.
    1) for a cat-less setup, you should not have the middle resonator deleted, if this is the case, you will drone no matter what
    2) You should put the x pipe as far forward as possible.
    As such, this is what I've decided to do. I'll let you guys know how it works, and post some sound clips after it's done.
    May 08 2018
    Berkeley, CA
    So. I ended up just replacing the baby resonators with the magnaflow part. The center piece is sill the same. Worked like a charm. I'll post audio when I get it.
    May 08 2018
    Berkeley, CA
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    I've gotten some really annoying rasp after putting on a Milltek x-pipe, sounds like a civic like someone mentioned above. Your car sounds just about perfect in that video.
    So just to clarify, your setup is: gutted cats -> Magnaflow 11385 -> stock center res -> stock rear mufflers?
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by melomandn View Post
    No center res. That's an x pipe (non resonated). I thought i would have to put resonators in there, but ended up not needing too.
    Active Member Two Rings Audiraz's Avatar
    May 19 2016
    Colorado Springs co
    My passenger side cat cracked. So I decided to replace with JHL test pipes. Now, between 2,000 - 4,000 rpm, it sounds like I riced out my car. My current setup:
    JHL test pipes > stock down pipe > custom pipe > stock muffler
    @Morritse, sounds like you have about the same set up. But now you are: magnaflow 11385 (x pipe) > 034 x pipe?
    Your car sounds great! I want to duplicate it! Just not sure if I will achieve the same result, with test pipes, since you have gutted cats.
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by Audiraz View Post
    You're correct about my setup. I would bet that installing the magnaflow part would fix your issues. It's not really a resonator, so it doesn't discriminate against specific frequencies too much. So I don't think the type of cats you have will effect it's characteristics too much.
    Jan 02 2012
    Sounds great, how's the drone/rasp between 2100 and 2900 rpms?
    '11 B8 S4 6mt
    May 08 2018
    Berkeley, CA
    There isn't any rasp in that range whatsoever. I haven't had a chance to drive on a highway so I can't speak on drone, but it seems to be a lot less. The only thing I can complain about is a weird vibration at around 2k RPM. I think it's just a reasonance frequency of my system, but it isn't a big deal.
    Jul 02 2017
    Smyrna, DE
    I can offer a suggestion on this as well — Myself and a hand few of others using the 11385 and various semi-custom setups installed these to help with the exhaust vibration. Really cuts it down quite nicely:
    https://www.moparpartsgiant.com/part...2103612aa.html
    You can clamp or weld them onto a couple of locations on the downpipes.
    May 08 2018
    Berkeley, CA
    You talking about that vibration at 2k? You have that as well?
    Jan 03 2018
    South Carolina
    Does this take away the 2k - 3k tin can sound or drone? I have all factory with Becker cat-less pipes, what's my next step?
    2014 S7
    2012 Oolong Grey A7 | DP 91-104 tune| Merc Hx| 57/187mm| Cat delete| Magnaflow x-pipe| ported SC TOTALED
    Apr 04 2017
    Chicago IL
    I'm currently still finding my exhaust overly drone-y. I've exhausted the existing milltek parts catalogue but don't want to get rid of my milltek exhaust. I'm thinking I'll probably just live with my set-up for now, but I may look into having my milltek non resonated downpipe hacked into something a bit different down the road.
