Results 1 to 6 of 6
Hybrid View
    Feb 02 2018
    2012%20A4%20Avant
    Livonia, Michigan
    APR 3" cast HFC and downpipe without stage 2
    I have a 2012 Avant with 2.0T and just installed the APR 3" cast hfc with the downpipe but at this time do not have any stage 1 or 2 ECU upgrade. Yes I'm getting a cel because I don't have the stage upgrade. The car is not my daily driver I have a company car for that. My question is will driving the car without the stage upgrade damage the engine? I plan on getting the APR stage 2 upgrade soon but was wondering if I will do any harm in the meantime.
    Thanks for you advice
    Veteran Member Three Rings Brandon K.'s Avatar
    Apr 17 2016
    2017 Golf R, 2018 Q7 3.0T, 1991 Saab 900T
    Vancouver WA
    Quote Originally Posted by Bellringer View Post
    No, it should be fine. The stock tune should not push anything harder than stock and therefore should not cause any problems. Were people run into trouble is when they use a tune that pushes the motor with the wrong parts.
    Even a K04 car is fine running the stock tune from both experience and what I have been told.
    Feb 02 2018
    2012%20A4%20Avant
    Livonia, Michigan
    Thanks for the info Brandon I was hoping for an answer like this.
    Senior Member Three Rings tominabox1's Avatar
    Nov 08 2017
    DFW
    on B8 cars you should be able to use an o2 sensor spacer to get the CEL to stay away.
    2014 A4 Quattro // Sport Package, Black Optics, Bang and Olufsen
    IE Stage 2, CR-15 Strut Brace, USP High Flow Cat, Spulen turbo inlet pipe, aFe filter
    Veteran Member Four Rings wkhanna's Avatar
    May 12 2017
    finally got cleaned so i moved
    Land of Archaic Anachronisms
    Quote Originally Posted by tominabox1 View Post
    ...this worked for me when i had just hfc & dp.....
    Billy
    Practicing Curmudgeon & Audio Snob
    2011 A5 2.0T Old Man Project
    Philips SimplyGo Mini o2 oxy concentrator, fully optioned
    Drive Med Walker, BBS, Brembo BBK, Kenwood 8 Track
    Avatar Chart
    Apr 17 2016
    Vancouver WA
    The spacer did not work for me. My APR stage 2 with their high flow cat in “stock” mode worked fine with no CEL for months. Eventually it would trigger a CEL (cat efficiency below acceptable threshold) in stock mode after the cat had some miles on it. I tried the spacer trick and it made no difference. I even had one of the spacers with the variable office size adapter.
    The tune I am using now does not have a switching feature, they just code out the 2nd O2 sensor. In my area, they stopped doing emissions tests if your car was made after 2008, so it is not a problem for me.
