Results 1 to 2 of 2
Thread: Foxwell Coding
    Established Member Two Rings KM1.8T's Avatar
    Aug 31 2016
    Winter Haven Florida
    Foxwell Coding
    Purchased the Foxwell scanner a while back to use to reset service lights and read codes if needed. Never thought I would attempt to try some coding with it.
    So I decided to experiment with some coding anyway, I was able to enable my Gauge needle sweep with the Foxwell. Was a little scary to change the code and the first time I tried I enabled the sweep along with the lap timer, that meant I lost my trip info screens. Was able to get it back to the original setting and after a couple of tries, the sweep is working and now the trip info is back. Guess as long as you can put original codes back, it is ok to experiment.
    Active Member One Ring mshane1's Avatar
    May 08 2012
    Illinois
    I just bought one of these and for the life of me can't figure out how to reset the service reset indicator light. Could you let me know how you accomplished that.
