Results 1 to 6 of 6
    Veteran Member Four Rings Moose201's Avatar
    Aug 26 2012
    2013 S4 Ibis 6MT
    Anybody have a pic of the front splash shield w/fasteners installed?
    During a vehicle service, the dealer completely dicked up the front splash shield. When the tech reinstalled it, he jettisoned all eight steel fasteners and instead used 4 zip ties (plus the three rear bolts). The real kicker is the two new bolts that he installed in the front that I can’t remove....they just spin and spin but don’t loosen and I can’t access the other side to see what they are attached to. I just want to see a clear pic of what it is supposed to look like so I can show the service manager how the tech botched the simple task of reinstalling the splash shield.
    www.coldwartourist.com - Exploring ruins & relics of The Cold War
    Prior: 2006 S2000, 2005 S4, 2004 Mazdaspeed Miata, 1999 M3
    Veteran Member Four Rings Jroyalty7's Avatar
    Jan 10 2016
    Porsche Macan Turbo
    FL
    They're probably the push and twist style fasteners. Sometimes mine get stuck you have to pull down on the shield while unscrewing it. Should come right out.
    Sent from my SM-G955U using Crapatalk
    Current: ‘21 RS5 Sportback B9.5 Nardo Grey
    Retired: ‘13 S4 B8.5 Phantom Black Pearl
    EPL Stage II DP Tune | EPL 57.60mm SC Pulley | 183mm Fluidampr Crank Pulley | S4Matty Ported SC and TB| Aquamist WMI 375cc Jet @ TB| AMS Alpha Heat Exchanger | Milltek Sport Non-Resonated CBE | ECS Kohlefaser Luft-Teknik Intake | Alu Kreuz | CR-15 | 034 Drive Train & Trans Inserts | Bilstein PSS10 | SPC Upper Control Arms | TSW Bathurst 20x10 | Pulley Ratio=3.177
    Aug 26 2012
    2013 S4 Ibis 6MT
    Quote Originally Posted by Jroyalty7 View Post
    Okay, I figured out what happened. The two new ones he installed were just regular screws and once screwed into that sort of opening, can’t be unscrewed. I was able to shove a flathead screwdriver between the panel and the attachment point, apply pressure until the threads fatigued enough to pop out. It would have been simpler if the tech had just saved the damn fasteners and reinstalled them. Sheesh!
    Jan 10 2016
    Porsche Macan Turbo
    FL
    Quote Originally Posted by Moose201 View Post
    Yeah it's a shame, you really cant trust people to just do their job anymore... always have to double check their work smh
    Aug 25 2013
    florida
    During a vehicle service, the dealer completely dicked up the front splash shield. When the tech reinstalled it, he jettisoned all eight steel fasteners and instead used 4 zip ties (plus the three rear bolts). The real kicker is the two new bolts that he installed in the front that I can’t remove....they just spin and spin but don’t loosen and I can’t access the other side to see what they are attached to. I just want to see a clear pic of what it is supposed to look like so I can show the service mangler how the tech botched the simple task of reinstalling the splash shield.
    fify - what in the actual f with the screws and zipties? was this an actual audi dealer or a local craigslist "shop" you might want to consider having an indie shop look at the work performed on your car if the first shop couldn't handle the technicalities of r&r a splash guard.
    2014 sfeux p+ 6mt bo nav w/o sd
    Aug 26 2012
    2013 S4 Ibis 6MT
    Quote Originally Posted by Oloung1 View Post
    The water pump failed as we were returning home from Florida (lost all coolant) and the closest Audi dealer was several hours away in Memphis. (I called them 7 times and they never answered their phone!) Next best thing was a VW dealer 30 miles away in Tupelo so that’s where I had AAA flatbed the car. They actually got us in right before closing on a Saturday and diagnosed the problem. I met the tech and he seemed to know all about the 3.0T engine, where the water pump was located and so forth. Why he couldn’t handle a simple plastic shield is beyond my comprehension.
