Results 1 to 13 of 13
    Established Member Two Rings mi1rmac's Avatar
    Mar 20 2018
    Help diagnosing rattle on start up- Video
    Hey All,
    Trying to chase down a rattle that only occurs on star up sometimes sounds like it coming from the middle of the vehicle not the engine. Car is completely stock.
    Any suggestions what it is?
    https://www.flickr.com/gp/44704288@N06/3M377A
    Senior Member Three Rings Sukks2bu's Avatar
    Mar 12 2013
    Milton Ontario
    Maybe downpipe or baby redonators
    - - - Updated - - -
    Maybe downpipe or baby resonators
    Veteran Member Three Rings Teamnct4's Avatar
    Aug 06 2010
    2015 S4 & 2022 S4
    NY & SC
    Has been happening on my 2015 since I bought it new. Doesn’t seem to be anything harmful from what I’ve read. Happened with my stock exhaust and with my AWE.
    2015 S4 Premium Plus, Mythos Black, Black/Magma Red Interior, Black optics package, Aluminum Mirror Caps, Carbon Atlas Inlays, Airlift 3P, Airlift performance front and rear shocks, AWE touring with 102MM Tips, E-Codes, 20X9 HRE FF01.
    2020 RS3
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    It is common and I've heard several speculations re: what it is, but there seems to be no consensus.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    Bumping this old thread as I have the same noise. Anyone else have this or knows what it’s coming from?
    Thanks
    Senior Member Three Rings BEight SFour's Avatar
    Oct 13 2019
    Alpine White E36 M3.. RIP rear ended
    Bay Area CA
    You guys check your cats? Flex pipe?
    On the E36 forums i use to go on the main cause of that rattle on start ups would have been those. Even if you think it's still good theres probably a crack some where.
    Sent from my SM-G955U using Audizine mobile app
    Mar 20 2018
    FWIW I have now replaced my exhaust with AWE resonated downpipes and a touring catback. Noise still persists.
    Even watching exhaust videos online numerous car have this same vibration. Crazy to think no one has figured out what it is.
    Established Member Two Rings gfro1234's Avatar
    Nov 27 2008
    Mountain View, CA
    Does it sound like this: https://www.audizine.com/forum/showt...t-V6-3-0-TFSI?
    If so could be your cam chain tensioner
    Aug 07 2007
    B7 ABT Avant
    Not the chain tensioner. I have that as well and this is different. It’s more from the middle to rear of the car.
    Aug 07 2007
    B7 ABT Avant
    You know what, maybe it is the chain tensioner. I don’t hear that secondary rattle if I don’t get the chain rattle.
    Mar 20 2018
    Quote Originally Posted by ABanT View Post
    The noise begins roughly 1-2 seconds after the car starts and isn’t coming from the engine bay, additionally it happens regardless of cold start vs warm engine.
    My understanding is chain tensioner noises are immediate upon startup and mainly happen during cold starts. Given this I think this rattle is different, but honestly who knows.
    Aug 07 2007
    B7 ABT Avant
    I also didn't think it was related to the chain tensioner at first.
    I started my car a total of 10 times today in two sessions, 2 cold in succession and then 3 warm. I got the secondary rattle on the cold starts and none on the warm.
    Did it again later in the day and it was the same thing. No chain rattle, no secondary rattle from the mid/rear of the car.
    Maybe the chain rattle is echoing so that it sounds like its coming from the rear? When the oil pressure builds something rattles. Sounds like a robot having a spasm.
    Apr 16 2017
    Illinois
    It might be related to your OEM flex pipe. Is it worn?
    2012 S4 | DSG | Prestige | Stage 2 | 187mm Fluidampr | AWE Touring | Eurocode Sways | 034 Insert | CR-15 | Forge Charge Cooler | ECS Carbon Intake
