Results 1 to 8 of 8
    Jun 10 2011
    Tampa, FL
    HELP Car threw 24 codes at once!
    Looking for a bit of insight before I take it to the dealer, so here it goes....
    2009 A4 B8 Quattro Sport Package 115k miles.
    Commuting this morning while accelerating from red light, almost the entire dashboard lights up including ESP, ECS, even the parking brake failure? Huge loss of power, engine shakes and exhaust spits black smoke. I am barely able to limp it to the nearest Firestone/Tires Plus and they run the codes.....24 in total.
    They are able to clear all but one related to the fuel pressure. There system says the on-board computer is telling the engine it needs 2500 psi when apparently it needs no more than around 400. They claim this is impossible and something they never seen before. They say it would explain the misfires and smoke as the engine is being dump with fuel. They recommend not driving it (it is barely driveable at this point) and get it towed to the dealer to check the computer etc.
    Will be taking it in tomorrow, any thoughts on what has happened? I like to go into the dealership with as much information/knowledge as possible.
    Thank you in advance.
    Jan 15 2017
    Fuel pressure is the least of your problems, and it is definitely in the thousands of psi, the LPFP should give somewhere in the 40's to 50's
    Seems like your timing slipped since you have a 2009. Don't try to start the car until a mechanic can tear the covers off and see what shape the valvetrain is in. And for all that is holy don't go to a dealership, an independent audi/VW shop will definitely be cheaper.
    Nov 20 2016
    At idle the fuel pressure should be around 550psi, at WOT you will see around 2500psi. Low side fuel pressure is probably somewhere between 45-65psi but i dont have the spec in front of me.
    Nov 20 2016
    Did they give a print out of the codes you have?
    Jun 10 2011
    Tampa, FL
    Nah, I had to run out of there for a meeting & forgot the list, but will grab a copy tomorrow.
    - - - Updated - - -
    Quote Originally Posted by Reciprocity View Post
    Thanks for your response. Timing slipping is a 2009 thing?
    Senior Member Four Rings
    Aug 17 2015
    Michigan/Ontario
    Quote Originally Posted by Flexfx View Post
    It's an Audi thing.
    In all seriousness, the 2009-2011 CAEB 2.0T are very prone to timing tensioner failure, which causes the timing to jump and your pistons to crash into the valves. Usually catastrophic damage to the engine.
    Actually, this class action lawsuit just got approved. So here is some ammunition for you:
    https://topclassactions.com/lawsuit-...on-settlement/
    https://www.audizine.com/forum/showt...-Thread/page25
    Jun 10 2011
    Tampa, FL
    It's an Audi thing.
    Wow, wow, WOW. Thank you for bringing this to my attention.
    With this information, what do you guys think my best course of action if indeed it is timing chain issue and the engine is completely blown? If I get the engine replaced, should I expect similar issues in the near future? I was not in the mindset of going car shopping but it sounds like I may need to. KBB values it "working" around $7k, engine replacement cost what...$6500 or more? Other $$$ factors can play into it but what do you guys think? Any input is helpful.
    Thanks again,
    EDIT/ADDITION. If I am reading this right, I would not qualify since my car has over 100k miles?
    "For timing chain replacements, customers will be reimbursed 100 percent of the paid dealer invoice amount for the covered part(s) and labor repairs or replacement of the timing chains at authorized Audi or Volkswagen dealers within 10 years or 100,000 miles (whichever occurs first) from date the vehicles went into service."
    Jun 10 2011
    Tampa, FL
    Just an update (hopefully it will help someone in the future).
    German mechanic confirmed the worst: timing chain & total blown engine. He had an A5 in the lot that had the same issue. Owner took an Uber to the dealership and purchased a brand new A5 the same day. Unfortunately, I was not prepared to drop those coins on a new Audi. German mechanic said "just go it a Toyota or Honda and you will be worry free". After two weeks of research and digesting everything, we picked up a brand 2018 Honda Accord Sport 2.0T.
    Having an Audi has been both a great pleasure and a heavy burden (oil burn etc). Thank you to everyone here in the B8 family. It was fun!
