Results 1 to 4 of 4
    Senior Member Three Rings red4life5's Avatar
    Dec 29 2016
    Saratoga Springs, UT
    Dynamic Steering....? Yes?
    As in previous posts my car had the CCM(comfort/convenience control module) replaced which got rid of all my vag com codes. Before I had dynamic steering set up so my steering got really stiff. Iíve gone back through and coded all the right things but I still canít get it to be stiff; any ideas?
    2010 A4 S-Line Prestige
    Oct 21 2012
    Earth...
    So, you have DYN steering option in your car pr 1N7? If not, no point to enable this, just activate "normal" steering option under ads etc, use drive select thread! Comfort module has no relation with steering, probably bcm01(j519) was replaced!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Dec 29 2016
    Quote Originally Posted by Gunnark100 View Post
    I donít have the option on my car but I want stiffer steering. There is a point, because I want it :D The CCM has to have some relation or the vag coding would still be there
    Dec 29 2016
    I found it. Itís module 9 byte7. Turn it to 00 and youíre golden
