Results 1 to 8 of 8
    Oct 27 2006
    Currently only S4
    Fort Walton Beach FL
    Items for Sale
    NV emission test
    i have a 01 S4 with 151000 miles. Trying to pass nevada emission test. had problems with test last year on evap system and had to replace gas tank due to cracks. This year, about a month before test, i got a CEL for cam adjustment. Ended up changing hall's sensor. Now, i can't get the evap or oxygen sensor tests to complete. I've driven about 400 miles since reset and they show "failed or incomplete test" on VAGCOM.
    I appreciate any help. Tks.
    Rob
    Oct 27 2006
    Currently only S4
    Items for Sale
    Sorry, should have mentioned k04 turbos, bigger injectors, downpipes, apr exhaust. I am the original owner, avant.
    Established Member Two Rings TheMysticWizard's Avatar
    Aug 15 2016
    '15 A3 TDI, '14 Q7 TDI Prestige, '06 VW Jetta, '01 Allroad, '87 TransAM
    East Bay, CA USA
    With k04's and bigger injectors, i'm assuming you have a tune... are you sure they weren't coded out?
    Jul 04 2012
    Woodbridge, VA
    Items for Sale
    Set readiness through VCDS and see where it is failing. It should give some information.
    Jun 07 2005
    Shepherdstown, WV
    Quote Originally Posted by TheMysticWizard View Post
    "coded out" items would show as passed in normal Audi Engine readiness diagnostics because Audis system is binary. Example your EGR one will always showed passed immediately after a code clear because it was never "coded in" from the factory. If you go over to generic OBD2 (what you need to look at for an emissions test) you will see that the EGR just shows as not installed, while if some tests ran it would not show passed on the ones that are installed or failed/not run on the ones that did and failed (or didn't run).
    As vavJETTAw36 suggested run through the readiness setting procedure manually to see if they run and pass, so much easier than driving around hoping conditions are met.
    80 rabbit pickup, 98 TJ 4bt cummins, 00 180TTQ 6spd, 02 Freelander, 03 Allroad 2.7t 6spd swap now with K04s, 06 A3 2.0T w/GT3071R (2012 JSW TDI and 2015 GSW TDI now in TDI purgatory )
    Aug 15 2016
    East Bay, CA USA
    Quote Originally Posted by chris86vw View Post
    Hm, OK. Wasn't totally sure how that worked. Maybe it's different on different years and such.
    Once upon a time I had a APR Stage 2 '09 CC that I put in "stock" tune and took for a smog test. It failed because the rear O2 sensor wouldn't show readiness. I contacted APR and they told me it would never show readiness, even in the "stock" tune they programed on my ECU, because in stage 2 form you need a downpipe which is either non-catted or has a high flow cat which would trip a CEL if it were not coded out.
    Feb 17 2011
    Quote Originally Posted by rob View Post
    Damn, original owner... not many people can say that about a b5.
    Jun 07 2005
    Shepherdstown, WV
    Pretty much works the same. The state saying they could not see the test just meant that it was showing as not installed on the generic OBD II they use, has you looked at it on your CC through VW/Audi system it would have just showed passed.
