Results 1 to 12 of 12
    Feb 03 2017
    2008 Audi A6 3.2
    Lehi/Utah
    Brake Vacuum Pump Replacement
    Does anyone have good instructions/video's for replacing the Brake Vacuum Pump on a 2008 A6 3.2?
    May 23 2016
    Edmond, OK
    -Remove front engine cover thing
    -Break off the OE clamp on the vac hose coming out the top of the pump
    -Pull off the hose (it's just a barb fitting so it will pull off with some TLC)
    - Put some rags under the pump/ over the alternator to soak up the engine oil that will come out when the pump is pulled off
    -Skip the 3 front cover plate bolts. These are irrelevant for mounting the pump (as I learned my first time removing it), and feel around for 3 Torx bolts (do not recall the size, T30/35/40, one of those IIRC). I think you can SEE the top one, but the lower two you must feel for. If you have your new pump handy you can use that as a reference to finding the bolts on the old one
    - Remove these 3 mounting bolts and you will likely need to pry the old pump off. Make sure you pry it out evenly, a little on one side, then match it on the other side, etc... until you remove it. This pump connects to the end of the camshaft so you do not want to put any unnecessary stress on this end by doing all your prying from one side only
    - now that your old pump is off, NOW before anything, lay it next to your new one face down, and MATCH THE END THAT GOES ON TO THE CAMSHAFT (just spin the pump's mechanism until it matches the alignment of the old one). This is so that when you go to place the new pump, the end is lined up with the camshaft's end so it will make installing much easier.
    - Remove old gasket and clean the mating surface
    - Place the new mounting gasket on the new pump. You can hold it in place with 2 torx bolts until you get these threaded
    - Install is the reverse of removal
    Note- When installing the new pump, it is normal for it to give you resistance when bringing it down on to the camshaft end. As long as you know it's lined up properly, bring it down SLOWLY AND EVENLY with the 3 mounting bolts. It's going to give you resistance, but it should move in as you do it. Remember that camshafts spin at 2x crank speed, so with our redline, the cams spin at 13000rpm, so this pump being attached to it has absolutely no slack. It's a tight fit. However, if you feel you are tightining and it's not moving down/ giving too much resistance, stop and confirm alignment!
    MOST IMPORTANT NOTE- NEVER EVER EVER remove the pump's cover plate. It's a new pump, there's no reason to pull this off. If you break this seal, you may be kissing the pump good bye, so don't. Do it on your old pump if you want to explore its guts, but not on the new pump.
    Good luck! This is quick, shouldn't take you more than 1/2hr is you're focused.
    EDIT- have a new worm-gear clamp ready for when you re-install the vacuum hose back on to the new one
    Apr 14 2011
    Rutherford, NJ
    the other 2 screws are located under the vacuum hose.
    Feb 03 2017
    2008 Audi A6 3.2
    Lehi/Utah
    So my pump is leaking. Does that necessarily mean I need a new pump or just a gasket replacement? Or is it one of those things where if you are taking old pump off, for the price of a new pump you might as well replace it? And the last question is, would you only buy an Audi OEM pump or are NON-OEM parts just as good?
    I also found this video. Seems to be the same as the instructions above: https://www.youtube.com/watch?v=0DntHmDXUxU
    May 20 2013
    yokohama/kanagawa/japan
    There is a rebuild kit. I just ordered it. See how it works.
    https://www.rkxtech.com/collections/...acuum-pump-kit
    And they have a YouTube video too.
    -tishi
    May 23 2016
    Edmond, OK
    Oh that's cool! Please let us know how this works for you.
    Feb 03 2017
    2008 Audi A6 3.2
    Lehi/Utah
    Yes let us know when you change it. Are you working on a 08 3.2 FWD car or a different model?
    May 20 2013
    It's for 06 C6 3.2l. Looks very simple job according to their video. But it's AUDI so you never know until actually do it.
    May 23 2016
    Edmond, OK
    I could not wait. I placed an order for that RKX tishi found . I'll give it a try. I figured if it doesn't work, I'm only out $30 and 30mins of my time. I'll report back as well once I install it, and a few days after the fact to follow up on if it fixed my oil leak there or not.
    Thanks again Tishi!
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    1994 Volvo 850 Turbo
    I used that same rebuild kit a couple months ago. Works great
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Need MMI 2G High update info? PM me.
    Veteran Member Four Rings JPJ2007's Avatar
    Apr 15 2009
    Middle TN
    I'll have to order this. I know mines bad, and I'm hoping it'd part of my vacuume issue
    Not opening the intake runner flaps
    2006 A6 3.2L Quattro S-Line (got my baby back)
    May 23 2016
    Edmond, OK
    So I can say the RKX kit looks top notch!
    You can't go wrong for the price as long as you install the pump correctly (I did not want to threadjack this thread, so I started a different one). My only suggestion would be to go to Audi/ order online the O-ring that goes on the backside of the pump where it enters the head. This kit does not include that o-ring and it would be smart to replace that as you are already in there replacing the metal mounting flange gasket. That's it though! Great kit otherwise. Thanks Tishi for bringing this up
    TIP- 7ft-lb = 84in-lb. I'll give you the conversion since most ft-lb torque wrenches start at 20ft-lb... but you can use an in-lb torque wrench and it's well within its range
