Results 1 to 4 of 4
    Senior Member Three Rings Azoriano's Avatar
    Jun 28 2013
    2009 S5 V8 4.2l
    Items for Sale
    Advice needed on P2188 code
    Looking for advice from the group. I drive a 09 S5 V8 with Awe Intake. I've been getting P2188 code running to rich on bank 1. I've cleaned the Mass air flow sensor and changed air Filter in case it was dirty. I also tested my o2 sensors to ensure they are working.
    Where else should I be trouble shooting?
    Any advice would be appreciated!!
    Jun 09 2017
    West LA
    have you change injectors and spark plug recently? could be those.
    you can also try to switch sensors to the other bank and see if the code follows the switch. like swap o2 sensors to the other side and if the code follows it is most likely the culprit
    Jun 28 2013
    2009 S5 V8 4.2l
    Items for Sale
    Just changed plugs and coils recently. That's all. I'm going to put my old coils back on and see.
    Established Member Four Rings wkhanna's Avatar
    May 12 2017
    needs cleaned
    Land of Archaic Anachronisms
    how many miles (kilometers) on the car?
    maybe a bad cat?
    Bill
    Practicing Curmudgeon & Audio Snob
    2011 A5 2.0t coupe
    2011 A4 quattro 2.0t (The Wife's)
    1983 Porsche 944 (modified)
    1985 BWM K100RS (since new - Heavily Modified)
    1971 Moto Guzzi Ambassador
    Avatar Chart
