Results 1 to 2 of 2
    Stage 2 Banner Advertiser Two Rings JRitt@Essex's Avatar
    Mar 21 2018
    C6 Vette, several miata, MR2, S2000
    Charlotte, NC
    Spiegler Stainless Steel Brake Lines for the RS3 now available!
    During the development of our Essex Designed AP Racing Radi-CAL Competition Brake Kits and 2-piece J Hook Discs, we also designed stainless steel brake lines that mate up to the OEM calipers front and rear:
    Front Spiegler SS Lines for Audi RS3
    = https://www.essexparts.com/spiegler-...ont-audi-tt-rs
    Rear Spiegler SS lines for Audi RS3= https://www.essexparts.com/spiegler-...ear-audi-tt-rs
    Stated simply, some of the automotive brake lines currently on the market are downright frightening. Looking at the fitting and assembly quality makes you wonder where the parts came from, and who put them together. Low grade carbon steel fittings, sloppy stainless weave, no abrasion coatings, substandard linings…the list goes on. When you consider that your brake lines are the critical safety link between your foot and your calipers, these facts aren’t exactly comforting. Not only are some of these parts suspect, it can take forever to actually receive them after placing an order.
    Spiegler does things a little differently. While you may not be familiar with the Spiegler name, they’ve been a trusted producer of stainless steel brake lines in the motorcycle racing industry for some time. Every component in a Spiegler brake line is manufactured to exacting standards in the USA or Western Europe, and these premium components are then hand assembled and tested at Spiegler’s facilities in Dayton, Ohio. You can buy Spiegler Stainless Steel Brake Lines with confidence, knowing that you’ll be receiving the finest product available for your car.
    You’ll also receive your parts quickly. When you have a track day on the horizon, you know you’ll have your parts in time to install them.
    Not only is Spiegler’s quality and delivery superior, they also provide some innovative features which solve some old problems:
    “Stress-free” Torsion Fitting System
    If you’ve ever installed a set of brake lines on your car, you’ve likely run into issues when trying to get the lines in proper orientation with the calipers. In order to be installed without anunwanted tension or stress, the line may need to be routed in a certain direction or angle with relation to the brakes and suspension. As you screw the banjo bolt into the caliper, the banjo fitting inevitably starts to rotate along with the bolt. You counteract this effect by pre-setting the line in a position counterclockwise of where you want it to actually end up, and then rotating it into position as you tighten the banjo bolt. This is called ‘clocking,’ and it can be a tedious affair
    Once you have the line tightened down, you’re done, right? Not exactly. While routing the brake line to the hard line attachment point, it’s very easy to introduce some twist into the line. That means you’re generating tension and strain on the line. When you turn your front wheels or go over a patch of rough road, that stress can be enhanced greatly.
    Most brake lines don’t have a solution for this dilemma. Spiegler lines fortunately do. The unique Spiegler Torsion System on the banjo fitting can be rotated, allowing for the removal of any unwanted tension in the line. Pop the line in your vice, give it a twist, and it’s much easier to position the line. These unique fittings allow for a cleaner install with less stress on the line, which means less chance of the line rupturing, or having unwanted contact with a wheel or suspension component.
    Abrasion Resistant Coating/Sheath
    All Spiegler Stainless Steel Lines come with an abrasion resistant coating. On the standard parts (non-custom colors), that coating is clear so you’re able to see the underlying stainless weave. The abrasion resistant coating prevents the line from snagging, protects the stainless weave from debris, and also allows the line to slide smoothly through any required retainers or brackets for a given application.
    Aircraft Quality Stainless Steel Fittings and Bolts
    When you drive your car in an environment as harsh as a racetrack, they’re constantly under assault from heat, tire debris, rocks, dirt, etc. In these conditions you need a high quality brake line designed to cope with these hazards. Spiegler lines are built tough, using aircraft grade stainless steel fittings and hardware. These components form the glue that holds the brake line together. Spiegler is so confident in the strength of their lines that they went so far as to dangle a sport bike from one of their brake lines (see above).
    Heavy Gauge, Tightly Woven Stainless Steel Braid
    The devil is in the details. Take a look at the Spiegler line above on the left, compared to a competitor's line on the right. Notice the tighter weave and heavier gauge wire on the Spiegler line. Spiegler lines are made from domestically sourced, heavy gauge, densely woven stainless steel braid, and you're getting far more stainless steel per inch than competitors offer. The result is superior pedal feel, strength, durability, and safety.
    Du Pont PTFE- Teflon lining, DOT Compliant
    Spiegler lines are made with proven, durable components you can rely on, such as a DuPont Teflon® inner lining. Every Spiegler line also complies with Department Of Transportation guidelines for automobile brake lines, so they’re perfect for your road legal track car or daily driver.
    Full Testing Battery on all Parts
    A lot of companies talk a good game about their “extensive testing,” but not many can back that up when push comes to shove. Spiegler makes it a priority to conduct a full battery of pressure, whip, and strength tests on their lines.
    Jeff Ritter
    Mgr.- High Performance Division
    Essex Parts Services
    Exclusive North American Importer of AP Racing, Ferodo, Spiegler, Mintex
    www.essexparts.com
    704-824-six zero three zero
    Established Member Three Rings shivaswrath's Avatar
    Sep 21 2017
    NJ/CT
    Very sexy
    2017 RS3 | Xpel in the front & Feynlabs all around | WINCOS IR 30% F and 20% R | 245/35-19 Pirelli Sottozero Serie II for winters | I'm not modding this super amazing car so I'm going to list stupid $hit like RS3 All season mats and Blendmount for Escort Max
