Results 1 to 5 of 5
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    VAG com wont connect
    Someone provide some insight... My VAG com will not connect for me to check logs. The cable just flashes a red light. I have used it many times before and the Ross Tech program is up to date. It must be a problem with my OBD port because my GIAC handheld tune programmer doesn't recognize my tune either. I looked under the dash and pulled back the plastic as much as I could to see the wiring to the port and it all looks fine. ????
    Established Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    2011 Silver S4, Mercedes Benz R350 ('07 & '11), Suzuki SV1000
    New Hampshire
    Quote Originally Posted by 4Rings3Liters View Post
    Bump and Sub'd. I had this same problem with the OBD and Vagcom, figured it was Vagcom or I was being dumb. Just went for inspection and he couldn't connect either but had the blue like.
    I'm EPL stage 2 and need to see if that works. The only thing I've done recently is replace the clutch line, that means I pulled the ECM/ECU out of that damn box. Have you done anything like that?
    Jul 04 2008
    York, PA
    Quote Originally Posted by Ford Prefect View Post
    Nope, I just went to log and noticed it wouldn't connect. Nothing has been done to the car lately.
    Jan 20 2017
    New Hampshire
    So oddly enough disconnecting the battery for a little bit seemed to have worked. I got in through vagcom and uploaded a new EPL file today.
    Good luck with yours. If I still canít get hooked up at my inspection Iíll post that.
    Jan 20 2017
    New Hampshire
    Need to bump this up. NH inspection machine still won't connect. I updated the EPL file and vagcom works. Anyone have any ideas? The inspection shows it's getting power but nothing.
