Results 1 to 9 of 9
    Senior Member Three Rings gk1's Avatar
    Aug 06 2014
    2014 SQ5
    32k miles front brake replacement S6, no issues, just hate the dust
    Finally got around to replacing the front brake pads with the Wearever Gold from Advance Auto. Sick of the horrid brake dust from the stock pads so figured I'd give the Wearever's a shot since other members have mentioned they have had good luck with them.
    Overall the stock pads were down about halfway. The rotors were at 36 mm so 16k miles/mm. Definitely could have gotten the other 16k miles out of the rotors and pads but the dust... the wretched dust....
    Anyway here is the price breakdown. (There are plenty of other good threads with pics and how-to's. Besides it is a pretty straight forward process.)
    Advance Auto Wearever Gold pads - $30
    New shim/dampers - $162 (I know others have re-used them but I am usually not so lucky when I try to re-use something like this.)
    Rotors - $560 (Revised part number 4H0-615-301-AL old part was 4H0-615-301-T. (I'm not sure what the change actually was though.) (Europaparts had them same day. Great place.)
    Brake pad wear sensor - $15 aftermarket (Definitely needed since the old one crumbles like paper mache.) Also there is only one on the inside driver's pad. (Some parts places say you need 2, one per side...not true))
    New caliper carrier bolts $28 (Again some re-use but it's cheap insurance to replace as recommended.)
    Only did a few miles bedding them in but feels the same as stock so far.
    2015 S6 Quartz Gray
    Black, Carbon, Night, Cold, DA, ACC, VCDS lowered, 034 Trans mounts, EuroCode Alu-Kreuz, APR v1.1 & TCU, Rohana RF2 20x9, {11.660@114.83 (4615lbs.)}
    2014 SQ5 Glacier White
    Black Nappa, Carbon, B&O, NAV, 21's, {stock 13.527@102.11 (4615lbs.)}
    2012 S4 S-Tronic Monsoon Gray {Stage II 12.868@107.8 (4275lbs.)}
    2008 A6 3.2Q S-Line Daytona Gray
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue {Stage I 14.746@95.29 (3944lbs.)}
    Senior Member Three Rings GilliamOS's Avatar
    May 26 2015
    '13 A6 3.0T Prestige | 2007 Ford Escape
    America's Buttcrack, Iowa
    Solid. That's a damn cheap price for the pads and honestly what they should cost. We've gotten so use to outrageous markups on stuff like that.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant
    2000 A4 1.8T
    1999 Millenia S
    1997 A4 1.8T
    1990 Maxima
    1987 Maxima
    1986 Golf Diesel
    Senior Member Three Rings spidey9999's Avatar
    Oct 19 2006
    The parts guy at my dealership says that when there is a revision to an item like brake discs it is due to a change to a different manufacturer for the part.
    Jun 23 2011
    Toms River, NJ, USA
    Thanks for the summary. I may be doing the same. In the past, I've used https://www.audiusaparts.com/ for brakes and rotors.
    I priced up the rotors and wear sensor. It came out to $551 shipped to NJ versus the $575 you quoted. Hey, every dollar counts.
    As for the shims / dampers, do you know what part number that is? I can't find anything on the S6 Brakes diagram that matches that description. I'm thinking maybe #9? If so, how many do you need? Is it 4 sets for 12 total?
    https://www.audiusaparts.com/auto-pa...nt-brakes-scat
    Mar 26 2010
    CA
    Audi Disc Brake Pad Shim Front (A8 Quattro S7 S8 S6) - Genuine VW Audi 4H0698231 Price: $161.79
    https://www.fcpeuro.com/products/aud...-vag-4h0698231
    Jan 13 2018
    Well, how is the dust??
    2014 S6
    Aug 06 2014
    2014 SQ5
    Quote Originally Posted by gimpgutter View Post
    My only issue with shipping rotors is since they are extremely heavy and they tend to get dinged up on delivery. I am not sure how they get delivered to the dealerships without much damage, maybe better packing materials from Germany, but they are fine when bought direct from there or Europoparts which is just like buying from the dealer but better price, but shipping something like that usually doesn't work out well in my experiences. I'll gladly pay a little more to be able to inspect and reject if need be. That last mile delivery is like Ace Ventura. LOL
    https://www.youtube.com/watch?v=UOJiEgxt7RY
    For the shims, as wwhan pointed out, this is the best I could find for the set.
    2015 S6 Quartz Gray
    Aug 06 2014
    2014 SQ5
    Quote Originally Posted by Dre325 View Post
    LOL
    Me no drivey much so car has not moved since initial post. I'll report back after driving a couple of days, particularly after the next car wash when the weather is better. With the OE pads the wheels would be black 2 driving days after washing them.
    2015 S6 Quartz Gray
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    Chicago area
    From personal experience on 2 differerent vehicles and in over 80,000 miles driven with these pads, the dust is all but non-existent.
