Results 1 to 5 of 5
    Jan 24 2013
    2018 RS3 |2014 B8.5 S5 stage 2+ |2010 MK6 GTI KO4 -gone
    Greater NYC
    Supreme Power | P3 Gauges: B9 S4/S5 OBD Multi Gauge & Analog Boost Gauge
    [B]
    Above is with Pre Installed OEM vent option sent as unit
    Above is Multi Gauge Only for self install in vent
    Audi B9 - P3 OBD2 Multi-Gauge
    SKU:
    vP3AB9X
    P3 Multi-Gauge
    Plug and Play install - just plug into your obd2 port and install into dash!
    Reads and clears OBD2 Codes
    OBD2 Data for Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Vehicle Speed, RPM, Shift-light, Battery voltage, 0-60 timer and more!
    Peak Recall on all functions
    Boost and Vacuum from OBD2 port
    Optional 80psi analog sensor
    Optional Auto-Dim or Manual Dimmer
    2 x universal 0-5v linear analog inputs
    Includes digital display, custom OBD2 wire harness and control box.
    OEM vent option
    We install the display in an OEM vent for your vehicle to make your install even easier.
    Track Pack software upgrade (GAS ENGINES ONLY)
    Adds Air/Fuel ratio through the OBD2 port
    Adds 0-100/60-130/60-0/100-0 timers
    Optional 80psi boost sensor
    Allows gauge to read boost directly from intake/charge pipe
    Plugs directly into the OBD2 harness (no wiring required)
    Can be added/removed from the gauge at any time
    P3 Gauges offer a Multifunction gauge that gives you the information you need while maintaining a clean OEM look. Starting at a price competitive to single feature old-school needle gauges, they offer unmatched feature to price ratio.
    All Multi-Gauges include an on-the-fly configuration menu for setting units (BAR/PSI, Farenheit/Celsius MPH/KPH), Shift light, analog boost sensor calibration and more. See www.p3gauges.com/install for more details.
    P3 Multi Gauge: $389
    Track Pack Add: $25
    Analog Sensor Option Add: $30
    Pre-Installed in OEM Vent Add: $300
    Shoot me an email with any questions or to order: Paul@SupremePower.com
    Email: Paul@SupremePower.com aka: allset
    Call or Text: 914-243-1993
    IG: paul_gi_5264 | FB: Paul Gi
    | 034 | ADV.1 | AG | Advan | Akrapovič | AWE | BBS | BC Forged | Brembo | Capristo | Forgeline | H&R | Klassen | KW | Milltek | Modulare | Neuspeed | Ohlins | OZ | Stoptech | Signature | VMR | Volk | Vorsteiner | Vossen | Work | & many more
    Jan 24 2013
    Greater NYC
    10% off sale on above pricing going on now for limited time!
    Jan 24 2013
    Greater NYC
    P3 B9 S4 MULTI GAUGE FLASH SALE!!
    ~START: Friday July 27th 12:01am (midnight)
    ~END: Monday July 30 11:59pm (midnight)
    Sale Details:
    Multi-Gauge sale ONLY!
    Normal base price: $389
    Sale price: $300
    Lmk if interested!
    Jan 24 2013
    Greater NYC
    B9 S4 MULTI GAUGE FLASH SALE ENDS TONIGHT !!
    Sale Details:
    Sale price: $300
    Jan 24 2013
    Greater NYC
    Gauges in stock!!
