Originally Posted by
B7S3wannabi
Have you done a resistance test on the injectors?
You can test at the injector harness plug so you wouldnt need to remove the intake.
Resistance should be between 1 and 4 ohms
Injector 1 - Red/Yellow and Black/Green
Injector 2 - Red/Blue and Green/Black
Injector 3 - Red/White and Gray/Yellow
Injector 4 - Red/Gray and Brown/Gray
Also. My injectors are made in Germany. By the Germans.
Thank you for the quick info there. i will go do a resistance test right now... but correct me if im wrong... resistance isnt the tell all test?
and the video they sent me of the injectors from china say "VW AG" printed on them... heres the video they sent me before i ordered:
https://drive.google.com/open?id=142...C0u4EsYTtZTQzr
EDIT: Did the resistance test as you described.
Injector 1 - open
Injector 2 - 1.2 ohms
Injector 3 - 1.2 ohms
Injector 4 - 1.1 ohms
how can i test the wiring now? unplug the connector at injector 1 and test the pins on the injector for resistance? my cheapass multimeter doesnt do continuity test, or it doesnt have beeper atleast.... how would i test the wiring harness?
I am an idiot. i found this on like the first page of google and it all makes sense now. its one bad injector causing misfire on 1 and 4 because they have same stroke?
Basic Step #1 First recommended step is to locate which "group" of sensors the manufacturer is referring to. With this information, you can then find the physical location of the injector(s) and their circuits. This may involve removing numerous engine covers and/or components to gain visual access (if possible). Make sure to inspect the harness for broken wires. Any worn-away insulation should be properly repaired with shrink-tube to prevent further and/or future issues.
Basic Step #2 At times, water and/or fluids may get "trapped" in the valleys where the injectors are installed. This increases the odds of the sensor's connectors, among other electrical connections, to corrode at a faster than normal rate. Make sure everything is how it should be and the connectors tabs are properly sealing the connection. Don't hesitate using some electrical contact cleaner to make everything connect and disconnect smoothly, not to mention the increased electrical connectivity within the connections with the use of this product.
Basic Step #3 Verify the integrity of the circuit by following troubleshooting steps provided by your specific vehicle's service manual. One example is to disconnect the supply voltage circuit from the ECM and at the fuel injector, then using your multimeter, determine whether or not the wires are in good working order. One test I like to do to determine quickly if there is an open within a particular wire which would help with code P2146 is to do a "continuity test". Setting your multimeter to RESISTANCE (a.k.a.: ohm, impedance, etc.), touch one end to one tip of the circuit and the other end at the other tip. Any higher then desired value may indicate a problem within the circuit. Any issue here will need to be determined by tracing the particular wire you are diagnosing.
Read more at:
https://www.obd-codes.com/p2146
Copyright OBD-Codes.com
Okay, so with my main connector unplugged that i just did resistance test, i will disconnect injector 1 plug and do continuity test on red/yellow to red/yellow and black/green to black/green on each end of the harness, then i will test resistance of pins on injector 1. thanks yall
