Results 1 to 5 of 5
    May 05 2017
    V8 FD RX7
    Adelaide. SA
    2013 RS5bIntake valve carbon clean up (Lots of pics...!!!)
    Hi guys, the last couple of week my 55000km RS5 was feeling a bit asthmatic, so overthe weekend I thought Il give cleaning the intake valve a try. First thing I noticed was how much more complicated are these cars compared to my FD RX7, remembering where things go later on proved to be a challenge, but I managed eventually with only 1 fault code lol.
    I was surprised how dirty the valves were after only 55000 km, it was caked up and I thought it was a good call to crack her open. I did everything by hand (not recommended)and used Liquimoly decarb spray which essentially turns the caked up hard carbon into oil like substance, plenty of satay skewers (bamboo, nothing metalic) and a detailing brush kit.
    FB_IMG_1526301479208.jpgFB_IMG_1526301468007.jpgFB_IMG_1526301483473.jpgFB_IMG_1526301461446.jpgFB_IMG_1526301476266.jpgFB_IMG_1526301473453.jpg
    Result was night and day, the car breathes freely now and Im booked in af Audi to clear the faulty code in a couple of days. The result as you can see are nuts, its not perfect but its much better than before...... so I am happy...
    FB_IMG_1526301487150.jpgFB_IMG_1526301497111.jpgFB_IMG_1526301493898.jpgFB_IMG_1526301487150.jpg
    Sent from my SM-T813 using Audizine mobile app
    Nov 03 2016
    CA
    Did you use a crank tool to cycle the slightly open cylinders shut before cleaning?
    2011 Audi S5
    (GONE) 2011 Audi A5 2.0T [APR STAGE 2] [034 MotorSports HFC]
    Established Member Three Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper
    San Antonio, TX
    Thanks for the pics!
    Doesn't look like the car is in the service position. Any gotcha moments?
    2013 Audi RS5 Misano Red, 20x10 Klassen ID M10/AWE Tuning Touring Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN Upper Control Arms/CR-15 reinforcement bar/ECS Stainless Steel Brake Lines/Apikol Rear Diff Bushing/ECS rear diff inserts/ECS front end links/034 Motorsports subframe inserts/034 Rear End Links/Tranny insert/E-code head & tail lights/Black Lip Spoiler, Red Trim Start Button, black emblems/VCDS.
    May 05 2017
    V8 FD RX7
    Adelaide. SA
    Quote Originally Posted by brilliant_black View Post
    I didnt, I just pressed the start button release it very quickly to turn the cam. But crank tools might be a better way of doing it.
    May 05 2017
    V8 FD RX7
    Adelaide. SA
    Quote Originally Posted by Ape Factory View Post
    yes, take pictures of everything before dismantling, there are buttloads of vacuum hoses etc under there. And doing it with a walnut blaster would have been so much faster and get better result.
