Results 1 to 12 of 12
    Sep 07 2016
    New York
    Anyone know location of fuse banks SF1, SF3, SF4 and ST4??
    I have an '09 Avant and I'm looking for these particular fuses and can't find where the SF1, SF3, SF4 and ST4 fuse banks are exactly. I thought they were all in the trunk in the location shown below, but those are showing as ST banks. Can anyone point me to these locations?
    SF1 Fuse 1
    SF3 Fuse 3
    SF4 Fuse 4
    ST4 Fuse panel 4
    https://www.audizine.com/forum/attac...&thumb=1&stc=1
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by 4lane View Post
    SF1 Fuse 1
    SF3 Fuse 3
    SF4 Fuse 4
    ST4 Fuse panel 4
    better ask what you like to find st is panel sf fuses which are in all panels!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Oct 21 2012
    Earth...
    Fuses in fuse carrier ST4 on fuse holder F -SF- (red)
    No. Current Flow Diagram designation Nominal value Function/component Terminal
    1 - Fuse 1 on fuse holder F -SF1- 15 A - 12V socket 2 -U18- 87
    2 - Fuse 2 on fuse holder F -SF2- 15 A - 12V socket -U5- 87
    3 - Fuse 3 on fuse holder F -SF3- 15 A - 12V socket 3 -U19- 87
    4 - Fuse 4 on fuse holder F -SF4- 15 A - Cigarette lighter -U1- 87
    Sep 07 2016
    New York
    Quote Originally Posted by Gunnark100 View Post
    I'm sorry, are you saying they are all located in the red circle here?
    Oct 21 2012
    Earth...
    If you looking fuses 1,3,4 in ST4 then yes, red holder. Real picture is a bit different as not all st carriers are there, depends of car options, so just go with "red"!
    Sep 07 2016
    New York
    I'm looking for these locations (locations are directly coming from the wiring diagram). Only one is noted as being in ST4, the others are all in SF1, 3, 4. So, assuming "ST4 fuse panel 4 means the location is in image above, then I'm looking for fuse carrier SF
    SF1 Fuse 1
    SF3 Fuse 3
    SF4 Fuse 4
    ST4 Fuse panel 4 {even though it doesn't say which fuse position, I'm assuming this is in fuse carrier ST4 per image above}
    Oct 21 2012
    Earth...
    What function diagram you looking. Problem with your question is that: example sf1 fuse 1 can be in each st!
    Sep 07 2016
    New York
    Here is the Wiring Diagram for my car and the area I'm investigating. I'm looking for the locations of the fuses that are highlighted.
    Oct 21 2012
    Earth...
    Ok, as you see on diagram each fuse is market st4 sf1 etc...so red carrier in trunk as i said above!
    Sep 07 2016
    New York
    Thanks for your help. I'm still not clear on what ST4, SF1, SF3, SF4 are referring to. I thought those were the particular fuse carriers the fuse can be found in, and the carrier in the trunk was only ST1 through ST5.
    Appreciate your help and sticking with me.
    Oct 21 2012
    Earth...
    No problem, just focus on black rings in your diagram
    st4(red carrier) sf1(fuse 1)
    st4(red carrier) sf3(fuse 3)
    st4(red carrier) sf4(fuse 4)
    st1-st5 all five are fuse panel F(STUPID A BIT I KNOW). I have only st2-st4
    Sep 07 2016
    New York
    Great, thanks so much
