So, I changed the coding in 17-Instruments and set the region to Germany to eliminate the chime when the door is open. On the B7 instrument cluster, apparently, you can hold the reset button on the washer stalk and manually set the cluster units and clock display. Well, this doesn't seem to work on the B6 cluster... at least not on mine (non-color) display.
Anyone know how to, or if it is even possible, to change the mileage units and the clock back to Imperial while keeping the region set to Germany?
Thanks.
