Results 1 to 12 of 12
    May 09 2018
    San Antonio, Texas
    Thumbs up 2001 Red B5 S4 6spd 12v VR6 swap with Bullseye S366 turbo, etc. -Dubuque, Iowa area
    Engine-
    OBD 2 12v Vr6 with 98k miles
    ARP Rod Bolts
    Head spacer
    ARP Head Studs
    Full ferrea valvetrain stock size in ported head.
    288 Techtonics Tuning Camshafts
    New chains, guides, thermostat, thermostat housing,
    Fluidampr crank pulley
    No ac or power steering(rack is looped)
    Modified cooling hoses hardlined for stock s4 radiator
    4 fan setup with two 7"pushers above the intercooler and 2 pull below one 12" and one 8"
    Custom engine mounts with ECS oem s4 mounts
    Modified aluminum valve cover with dual 10an ports for catch can
    Custom catchcan that needs to be finished back up
    oem obd2 vr6 throttle body
    Custom intake manifold with oem aluminum lower intake welded to a transition and boxed in with supports
    vacuum distribution block mounted on firewall
    Mk4 coolant bottle located in the cowl
    motorcycle battery located in the cowl
    blue igniter plug wires with Denso ik24 on oem mk3 ignition coil
    Early b5 pedal assembly for cable throttle
    Modified oem mk3 steel oil pan
    Fueling/standalone-
    Id2000cc injectors
    034 fuel rail
    All fittings are mostly Fragola with some IE and Aeromotive
    -8 ptfe lined feed
    -6 ptfe lined return
    Fuel lab pressure regulator
    IE dual 044 surge tank mounted into the space were the evap is contained in the center of the spare tire well under the car.
    AEM fuel pump in 034 basket in the stock fuel pump location
    Fuel filter before surge and fuel filter after surge tank.
    VEMS/Lugtronic standalone ecu mounted in the glovebox using a modified harness from lugtronic (originally for ce2 fusebox) with raychem heat shrink.
    NTK AFRM wideband mounted in the cup holder position
    AWE vent mount boost gauge
    Turbo/intercooler/exhaust-
    4.5"x12"x24" Garret intercooler core with Treadstone modified cast endtanks
    3" intercooler piping with 50mm tial bov
    Bullseye s366 with a divided .76 ar t3 housings 6 bolt outlet
    Kinetic manifold w/2 bolt tial 38mm wastegate
    Wastegate routed and dumped through a custom trim ring in the front bumper.
    3.5" SS downpipe routed into an awe twin 1 exhaust
    -10an return line
    -3an feed line
    Transmission/clutch-
    O34 aluminum flywheel with tilton twin disk cintered iron clutch.
    034/oem vr6 to 01e adapter
    034 high output starter
    New second gear installed with a jhm transmission rebuild kit
    New oem center driveshaft
    034 street density transmission mounts
    ecs rear differential mount
    Brakes/suspension/wheels-
    St coilovers
    oem rotors and hawk hps pads
    Replaced one rear tie rod and brake caliper recently
    oem ultrasport wheels
    This was a customer's build, originally. He ran it once at the track and took out the usual...the 1-2 shift collar. I bought it from him, as he didn't want to continue with the project, and I proceeded to fix the transmission by contacting JHM and buying their rebuild kit and the new second gear. We rebuilt the transmission and reinstalled it. I also had it tuned, for E85, by Brian Coombs who does a LOT of VRT cars. It now has more e-fans added and wired in, as well as a boost controller. I lowered it, slightly, with ST coilovers, too. The rear left window regulator is bad but it has a replacement sitting inside of it. The heater/AC controls also don't work. It pops fuses when powered on. It also needs a custom oil catch can, as the old one was accidentally removed and then damaged beyond repair by the previous owner. The idle control needs to be wired, too. The last two items are in the process of being looked into and straightened out. An attempt to get it dyno'd or maybe a track run is probable as well.
    Looking for $15k OBO.
    Thanks for looking!
    Rob
    Some pics, below:
    Established Member Two Rings AudiAlbany123's Avatar
    Apr 08 2017
    Old stuff
    sweet wheres the pictures?
    Established Member Two Rings Jargon's Avatar
    Dec 01 2017
    Oregon
    Avant, by chance?
    2006 A4 Avant 2.0T Quattro 6MT
    2003 BMW 325i Touring 5MT
    May 09 2018
    San Antonio, Texas
    Quote Originally Posted by AudiAlbany123 View Post
    Sorry, posted from my phone and it was being a little bit of a you-know-what and I couldn't edit the post.
    Please find the pics added now. Thanks for the reminder.
    - - - Updated - - -
    Quote Originally Posted by Jargon View Post
    Avant, by chance?
    I wish. :(
    May 09 2018
    San Antonio, Texas
    Remember the "OBO" part.
    Veteran Member Four Rings AudiForeman's Avatar
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    Does the chassis have 98k or just the motor?
    May 09 2018
    San Antonio, Texas
    Quote Originally Posted by AudiForeman View Post
    The motor has 98k.
    I believe the body has 120k-ish on it, but am not near it to check. Sorry.
    May 09 2018
    San Antonio, Texas
    Lightbulb Price updated
    Price updated: $14k or best offer.
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    Is the harness comparable with the or gauge cluster?
    May 09 2018
    San Antonio, Texas
    It's compatible, but the coolant level sensor and oil temp sensor aren't hooked up. But could be .
    The oil pan doesn't have an oil level sensor provision, though.
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    Is that something your going to tackle or are you just trying to offload as is?
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    Still available
