Results 1 to 2 of 2
    Mar 31 2018
    Florida
    Completed wiring for Keyless Go Retrofit - Help Needed
    Hello, I have been reading on this forum for a while and finally got all the part and finished the entire wiring of the Keyless Go in my S5 Convertible. Door sensors, and Antennas installed, start button completed, truck antenna and mmi antenna installed and wired. Installed new BCM module 8K0907064CG but now all I get when I go to start the car is "Please Remove Key" noted on the dash, and nothing else happens. I can start the radio, navigation, phone all appear to work fine. Key fobs don't unlock/lock doors so know those have to be programmed. Where did I go wrong. Did I get the incorrect BCM module by original module was the 8k0907064CF and as it didn't have the Blu 32 pin connector had to replace it.
    Anyone know how to fix or have any suggestions.
    2011 S5 3.0 Convertible
    Established Member Two Rings S5_SID's Avatar
    Apr 07 2018
    2011 S5 Quartz Gray Cab
    Orange County, CA
    Sorry I don't have an answer for you, but I do have a question if you don't mind me asking.
    Where did you purchase your keyless entry? Does this work just like the convenience package as well?
    -Sid
    Keep Deep Sea Alive!
    Deep Sea Diver 🇺🇸
    2011 S5 Cabriolet • Quartz Gray Metallic • 3.0T •B&O•Sport Seats• Peelers•Carbon Inlays•Mods to come...
