Results 1 to 9 of 9
    Established Member Two Rings Linksman72's Avatar
    Jun 23 2015
    Orland Park IL
    2014 S6 20” rims
    A set of used 20” rims from a 2014 s6. Good condition. One rim had a minor dent that was repaired by the dealership. Asking price $550 for the set.
    2010 Audi A5 Prestige 2.0t, Brilliant Black, APR Ko4, AWE Touring catback exhaust, AWE downpipe, 034 HFC, Kohlefaser Luft-Technik Intake System, Wagner competition intercooler, RS5 Grille, H&R Coilovers, Vorstiener vff 104 20x10, interior LED upgrade, 034 drivetrain mount inserts, Basslink subwoofer, VAG-COM mods
    Aug 10 2017
    So Cal
    Hi do you have the bolt pattern and offset specs, I need to see if they will fit a 2010 S4. Will you ship, I'm in So. Cal. Thanks.
    Aug 10 2017
    So Cal
    Hi I was able to compare wheel specs on wheel-size.com, it appears that your wheels would be compatible to a 2010 S4, were these wheels stock to your '14 S6? Do you any pictures of these wheels on your car? Thanks again.
    Junior Member Two Rings
    Jun 16 2014
    Buffalo, NY
    Willing to ship?
    Veteran Member Three Rings thorlax240's Avatar
    Jun 27 2017
    Boston, MA
    Quote Originally Posted by Chasing Cars View Post
    C7 Glacier S6 APR STG2 | APR dp's | AWE touring | Roc Euro | Eurocode F&R sways | 20" RS7 forged | 20" OEM rotors | -17mm VCDS | 15% Luminex | RS6 grill | transmission/differential inserts
    C7.5 Mythos A6 APR STG2 ECU+TCU | Single Pulley | Injen Intake | Eurocode F&R sways | H&R Springs | 17.5mm + 20mm spacers | 35% Luminex | transmission/differential inserts
    Jun 23 2015
    Orland Park IL
    Quote Originally Posted by JasonGA View Post
    Willing to ship?
    Yes willing to ship
    Aug 10 2017
    So Cal
    Hi after the dealer repair no issues with the wheel holding pressure? Can you please send me a text at 949 413 0523, interested
    Aug 10 2017
    So Cal
    Hi Linksmann72,
    Are the wheels still available?
    Aug 10 2017
    So Cal
    Hi Linksman,
    Are your wheels still available, last chance to reply or I'm moving on...thanks.
