Results 1 to 13 of 13
    Veteran Member Three Rings SoundEfx's Avatar
    Aug 29 2017
    2000 S4 - 2001 S4 - 2003 RS6
    PNW
    Help pulling a B5 S4 engine
    Hi everyone, Joel here. Long story short, my timing belt tensioner failed in my B5 S4, valves played drums on the pistons, zero compression in 4 out of 6 cylinders, so I didn't bother to check the other 2 cylinders.....lol
    The new (to me) engine is on its way, will be here Friday, but I have NO idea what I'm doing when it comes to taking this engine out. I have all the basic stuff disconnected, meaning, having it stripped down to the timing belt, but no further.
    I have looked at the youtube video many times, but we all know everything recorded looks easier than real life. Well, for me anyway.
    So I'm wondering if ANY experienced B5 S4 engine pullers out there are willing to help me out. Depending on when we start, breakfast, lunch AND dinner is on me, with brews if wanted.
    The car is on a lift and there are lots of the necessary tools are accessible (again, my knowledge is limited). So the only thing lacking is my knowledge of this car.
    Let me know if anyone is interested and availability.
    You don't even have to turn a wrench, simply guide me on what to do.
    Or any other guidance is appreciated.
    Thanks.
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    Where are you (or more importantly, the car and lift) located ?
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Aug 29 2017
    PNW
    Quote Originally Posted by 02 A6 2.7T View Post
    It's at the place called 'The Shop' in SODO.
    Aug 29 2017
    PNW
    Is the B5 so terrible that no one wants free food and beer? LOL....
    Veteran Member Four Rings PwrWgn's Avatar
    Sep 14 2013
    Hey man saw you at the shop earlier today, I was there working on my avant. Nice meeting you.
    What are your plans/goals with the engine replacement? Based on the condition of the engine you bought (from what I could see), I would try and pull most of the accessories from your existing motor. You should also invest in some gaskets and seals..other basic stuff while you're in there and it's all easy to access still.
    I live and work pretty closeby so could stop thru to help you out with the engine swap periodically if you like. Not sure of the timeline you are working with.
    Aug 29 2017
    PNW
    Quote Originally Posted by PwrWgn View Post
    Nice meeting you too man. Nice car as well.
    I plan to be in the shop almost every evening until I get my car running again. I plan to be there from 11 AM to around 3 today.
    Great minds think alike I guess because I did plan to take all of the good parts from my used engine and transfer them to my 'new to me' engine, especially the NEW timing stuff I bought.
    My goal with this engine is to simply get it running. No power goals or anything special and hopefully it last until AFTER I get another engine built.
    What I need help with is with the actually swapping of the engine. I can strip it down and swap parts, but when it comes to the actual getting it in and out of the car, I'm a lost soul.
    So any help and guidance will be appreciated and as said, food and beer is on me.
    Veteran Member Three Rings DoItAllGarage's Avatar
    Oct 29 2013
    WA to ID
    Quote Originally Posted by SoundEfx View Post
    Please do a leakdown test on the used engine before installing. For two reasons, 1) If bad, can return the LKQ engine for another one. 2) will avoid r&r an engine twice. Get a repair manual and take your time. You got this bro!
    Sent from my SM-G930V using Audizine mobile app
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    I would love to help but I don't have time to wrench on my own vehicles no a days. There are a few you tube videos out there though that give good guidance on what to do.
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Aug 29 2017
    PNW
    Quote Originally Posted by DoItAllGarage View Post
    Good point, thanks man.
    I'll do it this evening.
    Aug 29 2017
    PNW
    Quote Originally Posted by Eurotuned_A4 View Post
    I hear you man, thanks for considering it though.
    If you ever need help, I have no problem lending a hand in what I can do. So don't hesitate to ask.
    Keep on wrenching pimp.
    Veteran Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    If you can swap the parts over... you have more than enough skill to pull that motor.
    I started on the trans side and worked my way forward.
    Driveshaft
    CVs
    Trans Mounts
    Downpipes
    Shift linkage.
    Label the bolts clearly and specifically. There are not many.
    Support the trans with a jack or since it’s on a lift a stand.
    Move to the front.
    Pull bumper
    Pull headlights
    Disconnect radiator hoses and plugs from the front clip... mostly on the drivers side.
    Mark the 4 bolts holding the front clip with a marker,
    Pull AC out and condenser... condenser gets folded over and hung from the hood... use cardboard to keep it safe.
    AC will need to remove the oil filter block or cooler what ever that is to slide the AC unit put... slide it over and hang it from something.
    Now you can get to motor mounts
    Unplug wiring harness,
    Throw on top of engine.
    Unplug fuel line and vacuum lines, disconnect 2 grounds one is hiding under the pass side bumper frame, the other is connected to the main harness by the ECU.
    Disconnect heater core
    Check everything is disconnected
    Chain the motor unbolt your mounts.
    Pump it up pull a bit... check the engine everything is unplugged pull... set it down on a tire!
    That’s it ;)
    Now get to work... chop chop LOL.
    Oct 11 2016
    Connecticut
    Wish I was closer! Would love to help out.
    Aug 29 2017
    PNW
    Quote Originally Posted by JustManson View Post
    Driveshaft
    CVs
    Trans Mounts
    Downpipes
    Shift linkage.
    Label the bolts clearly and specifically. There are not many. This is good to know
    Move to the front.
    Pull bumper - Done
    Pull headlights - Done
    Disconnect radiator hoses and plugs from the front clip... mostly on the drivers side. - Done
    Mark the 4 bolts holding the front clip with a marker, - Done
    Pull AC out and condenser... condenser gets folded over and hung from the hood... use cardboard to keep it safe. - This is where I'm lost. Isn't it connected to the condenser?
    Unplug wiring harness, - Here is where I'm lost. I'm not sure if to disconnect it from the firewall connections or take it out all as one (IF that's even possible)
    Unplug fuel line and vacuum lines, disconnect 2 grounds one is hiding under the pass side bumper frame, the other is connected to the main harness by the ECU. - Step two after the harness.
    Disconnect heater core - Will try to disconnect from behind the engine because I've heard horror stories of damaging it when trying to remove from the firewall.
    Check everything is disconnected - Easier with more eyes watching.
    That’s it ;)
    Thanks for the info and this is why I'm reading your 'first time engine pull' thread over and over....lol
    The thing with me is that everything sounds easy when reading, but when it comes to actually doing it, I'm like "I know I'll mess something up"...
    I already have the car in service mode when I put the new timing belt and tensioner on to determine how dead the engine was/is, so all I have left are the underneath and wire harness and if I'm honest with myself, it's the wire harness that scares me.
    Looking back there at all the wires and hoses puts the shivers and 'WTF' thoughts in my head.....lol
    - - - Updated - - -
    I'll pay for your plane ticket....lol
