Results 1 to 6 of 6
    Dec 22 2012
    liverpool ny
    2014 s6 132k miles
    Hi guys, just sold my 2010 s4 manual trans and purchased a 2014 s6 with 132k. The car was meticulously maintained and all services were completed at Audi dealer. The trans is fairly jerky at times. Is this normal for a dual clutch trans? Car also shakes pretty roughly at idle intermittently while rpm gauge stays stagnant. Is this normal? Any input is appreciated!
    Veteran Member Four Rings Dutch_A6's Avatar
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    Can't speak to the transmission as I don't have a dsg, but the vibration at idle could be from work motor mounts.
    Sent from my Pixel XL using Tapatalk
    Black 2012 A7 Prestige
    Zito ZF01 wheels
    EPL stage 2 tune
    Tinted marker lights
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    Ya mounts are probably shot.
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Senior Member Three Rings GlacierS5's Avatar
    Jul 27 2017
    San Jose, CA.
    Yeah, run VCDS scan for any mount faults. As for the tranny, you may need to have the dealer do an TCU software upgrade. I believe it's version 0002.
    Sent from my Pixel XL using Audizine mobile app
    2018 Glacier White S5 | Prestige | Sports Pkg | Dynamic Steering | Carbon Fiber Pkg | 034 Motorsports Parts
    2016 Sepang Blue RS7 | Prestige | SRM Intake |EuroCode Sways
    2014 Glacier White S6 - SOLD
    Jun 30 2016
    NNJ
    +1 on motor mounts. It's probably due for a DSG service too.
    Senior Member Two Rings aFOURstance's Avatar
    Jan 30 2011
    '04 DBP R32 PTE6266 Turbo, '01 Nogaro S4 Stg 3 & Bagged
    FAIRFAX, VA
    2014 s6 132k miles
    Definitely needs new motor mounts, I would recommend getting them at audiusaparts.com unless you have the hookups at a dealership. They're $433.45 each and probably be best to replace both sides, with that said labor should be anywhere from 1300-2500 depending on where you go (local specialty shop vs dealership)
    I would highly suggest doing the DSG service also like someone suggested, of course only if you dont have records of this being done recently.
    You can get drivetrain mount inserts, 034 or eurocode, they seem to help alleviate some of the jerky feeling.
    There's always a risk and premium to high mileage vehicles. I hope you get it sorted out
    Life is too short to drive boring cars.
