Results 1 to 2 of 2
    Jan 07 2017
    B5 Passat
    Kittanning
    Oil Leaking From Valve Cover Gasket?
    Hey guys,
    I have been having oil leaking, as well as oil burning out of the exhaust of my B7 A4... take a look at these pictures:
    https://imgur.com/a/pKkIo0d
    Based on the oil welling up in the bolt housings, i'm guessing it's the valve cover. But why is it also welling up on top of the intake?
    I'm just wondering if replacing the valve cover gasket will fix this issue, or if there is more to replace.
    Veteran Member Four Rings wkhanna's Avatar
    May 12 2017
    finally got cleaned so i moved
    Land of Archaic Anachronisms
    just a poke in the dark...... is the seal on your oil fill cap in good condition?
    Billy
    Practicing Curmudgeon & Audio Snob
    2011 A5 2.0T Old Man Project
    Philips SimplyGo Mini o2 oxy concentrator, fully optioned
    Drive Med Walker, BBS, Brembo BBK, Kenwood 8 Track
    Avatar Chart
