    Apr 24 2018
    180,000kms - Maintenance Recommendations?
    Hi everyone,
    Just hit 180K clicks on my B8 S4. What fluids do you guys recommend that I should change?
    - Brake Fluid
    - Clutch Fluid
    - MTF Fluid
    - Supercharger Fluid? (Not too familiar with the 3.0T yet)
    - Differential Fluid
    - Power Steering Fluid
    Is there anything else that I'm missing/don't need changed? I want to put in practically new fluids on the entire car.
    Thanks
    Sent from my SM-G930W8 using Tapatalk
    Veteran Member Three Rings Snowmonkey's Avatar
    Apr 27 2018
    Kansas
    Dont forget your blinker fluid
    joking aside, Have you had any troubles in the past 40k? im about to hit 140K in mine and want to know if there might be trouble ahead
    Apr 24 2018
    I figured coolant flush also!
    Quote Originally Posted by Snowmonkey View Post
    Well, I picked up the car at 175,000kms, *knock on wood* under good maintenance. Would just like to go over fluids to prevent issues from happening in the long run.
    Senior Member Three Rings Phil.Lmbrt's Avatar
    Apr 12 2017
    La Sarre, Quebec
    I would do All fluids
    - Engine Oil (obviously)
    - Coolant
    - Brake
    - Transmission
    - Differential
    - Powersteering
    - Supercharger
    I would also do the following
    - Replace Belts (at least inspect them) if not done recently
    - Air/Cabin filters
    - Plugs if not done recently
    - Look for leaks/loose things all over the car
    - Fuel filter wouldn't hurt
    2012 S4
    Phantom Black | 6MT | Sports Diff | B&O
    IE Dual Pulley W/ TB | 57/187 Pulleys | Rabbit Hole Motorsport | CTS | USP | 034 | JHM | PLM | BFI | P3cars | Rotiform | CR-15 | Macan Calipers | StopTech | Hawk Performance| SPEC Clutches | Snow Performance | Airlift Performance | Accuair | Kühl Rennsport
    IG : Phil.lmbrt
    Apr 24 2018
    Quote Originally Posted by Phil.Lmbrt View Post
    - Coolant
    - Brake
    - Transmission
    - Differential
    - Powersteering
    - Supercharger
    - Air/Cabin filters
    Thanks a lot!
