1) My steering is heavier than it used to be. I mean, not toooo heavy, but still a big difference. Due to new rack or lower car? Not sure, but I hope I am now not putting excess pressure on my new rack. I did drive ~6 miles with no power steering fluid, how do I know if my power steering pump is dying?
2) After getting a full 4 wheel alignment done, everything is now within spec EXCEPT front left and right wheel chamber. On the print out I got, both are in the red (-1.18 and -1.40 respectively). All other points are green. I asked about this after the fact and they said they tried to get this into OEM spec (hunter machine), but couldn't as the car is lower and then other things started moving out of place. Does this sound right to anyone?
3) The car is lower in the rear than in the front. Is this normal? I expected the exact opposite to happen (higher in rear, lower in the front). I 100% put in the struts right, but in terms of the springs, the front ones are the larger ones, right? Also, was there only 1 correct way to flip them around? I mean, I put them back in a way that everything fit OK, but I did not take note of the springs direction (top vs bottom) before removing my OE ones. Could this affect ride height? Picture of the difference below.
