Results 1 to 3 of 3
    May 08 2018
    DC
    Timing Chain fixed? dealer not sure,
    Hi,
    I have a 2011 A4 quattro Premium + with 110k miles. Pulled my service history through the dealer:
    Serial No.
    Labor Operation
    Description
    Maintenance Paint Casual Package Part
    Engine complete removed+reinstalled Pistons removed+reinstalled
    Test drive .
    17160299
    OIL CONSUMPTION PART 2
    28202399 Parts items
    IGNITION COILS REMOVE+INSTALL
    17261913 24702599 17160199 13741963 13751913
    Pressure regulating valve rem+reins SVM UPDATE
    PART 1 OIL CONSUMPTION TEST Crankshaft seal,pulley end rem+rein Crankshaft vibration damper rem+rei
    01320000 15331914
    Technical check .
    Chain housing cover removed+reinsta
    This is what my dealer is saying:
    " it doesn’t look like the timing belt was performed. The timing belt package runs about $1800-2000 for the repair."
    I got the car used at 94k, was wondering since I plan to keep it for 1-2 more years whether i should get it done?
    Thanks in advance!
    Feb 24 2004
    Minneapolis
    Search around, lots of talk about this topic. Start here for one example.
    https://www.audizine.com/forum/showt...d?goto=newpost
    The PO had a phase 2 done at the dealer at 65,000 miles. At 85,000 I found the original early spec tensioner in mine. I'd look through the inspection hole, and if you see that original tensioner in there, I'd definitely do it.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Jun 27 2011
    Timing belt? Hah....
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
