Results 1 to 17 of 17
    Active Member Three Rings
    Feb 11 2015
    New Jersey
    Stage-2 Vehicles only! What does your LC work like any FW spin at all??
    I am stage-2 ECU / Stage-1 TCU
    I get front wheel spin on LC for maybe 2 seconds before I feel the rear kick in. I had the car coded by Audi, replaced Haldex Controller and Pump w/brand new units. Replaced the diff with a low mileage used unit.
    They flushed the Haldex system, did all adaptations and I still get FWS on LC and occasional TC light when pulling out hard off a turn (from a stop) out of my development.
    I am sick of this Haldex crap, I am being told that some people get wheels spin stock with LC until the rear kicks in, but specifically looking for stage-2 cars.
    Oct 30 2012
    Arizona
    My experience has been all 4 engage within a nano second with LC. However, I keep getting an off an on Haldex pump clutch fault. I haven't had that code pop up in a 3 months but it sucks big time when trying to lay the power down. it sticks around for a week or 2 and then back to normal. I don't know if the filter is getting clogged to what? I plan on flushing my entire drive system almost at 30K miles) and possibly flashing to the UM Haldex controller when I hear more feedback.
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    I was apr stage 2 and I launched it probably 30-35 times and it would have a small front spin.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Sep 14 2006
    I did until I increased traction via Obdeleven
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Jan 02 2018
    Silicon Valley, Ca
    More details please on the OBDELEVEN coding
    Veteran Member Four Rings ralphie_43's Avatar
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    I get lots of spin when I launch mine all the way through 2nd
    Sent from my SM-G930V using Audizine mobile app
    May 20 2011
    MS
    Quote Originally Posted by ralphie_43 View Post
    Your haldex is gone/going out.
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by liljonny16 View Post
    https://youtu.be/4WtiKbxKm18 took this quick video is it out or is there something I'm missing I can get a better video of need be
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Mine spins a bit, but its simple physics. The car digs hard, weight transfers back unloading the fronts so they roll over a bit. If they keep squealing you have a problem, but a bit of spin in the front is totally normal, even after increasing traction to the rear via coding (I did that too with VAGCOM)
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    May 20 2011
    MS
    There's nothing wrong there! I'm jealous! Never seen such a clean launch.
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    https://youtu.be/-assClxifHQ unfortunately I just took this video from a different angle and the haldex is in fact dead
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Update for me.. After installing all the 034 chassis bits and APR intake/Downpipe newest UNI files with the high torque settings and "increased traction" Via vagcom, and 4,000rpm launch on a hot day with sticky tires (just now) I had zero wheel spin front or rear. No drama at all, just traction and took off like a rocket. Odd that I was getting some front wheel spin before, even with the increased traction setting. Maybe Uni tweaked their launch settings.
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by Spinnetti View Post
    Did you replace your pump?
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Nope. Original pump as far as I know, 73k miles
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Ah ok I'm gonna replace mine because I'm spinning the front and I read somewhere on this thread that pump is the problem 90% of the time and I want to try that before i jump into the deep end and get a new rear dif
    May 20 2011
    MS
    I would suggest you get with someone with VAG-COM and check to see if you have any codes first. You definitely should after your video. That will let you know if it it's the pump or the clutch pack themselves. I just left the dealer yesterday and they recommended I replace my clutch assembly, 0CQ525554T. And the seal is N90443301.
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Will do for sure!
