Results 1 to 15 of 15
    Dec 08 2017
    Chicago
    Weird BOV sound after lifting off throttle
    after i get into boost and let off or switch gears there is a weird blow off valve noise, very loud, Any ideas been doing some research and the diverter valves could be the cause of issue
    Jul 04 2012
    Woodbridge, VA
    Sounds like leaky diverter valves (bad diaphragm). What DV's are you running? They tend to make more noise if they are installed backwards as well.
    Dec 08 2017
    Chicago
    i have the forge 008, full stage 3. Build list if needed: https://www.dropbox.com/personal?pre...3+S4+Avant.pdf
    Dec 08 2017
    Chicago
    Quote Originally Posted by vavJETTAw36 View Post
    Any suggestions on getting good ones, if it is a leaky dv would you suggest not driving or just stay out of boost?
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by Damian_H1 View Post
    Forges are Piston type DV's. They do not utilize a rubber diaphragm that can cause it to leak. Are these new to you? If so, it is probably a normal sound. I have turned my Forge 007's backwards to allow for a better fit with my WDR bi pipe. They are louder this way.
    If you arent having trouble making boost and your AFR's are fine, boost on my friend.
    Dec 08 2017
    Chicago
    Ok thank you very much
    Jul 04 2012
    Woodbridge, VA
    no problem. If you're not sure the last time the DV's were lubed, you may want to open them up and regrease them. This should be done at least once a year.
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    You may want to rebuild your valves---The kit is only $17 from Forge.
    https://www.forgemotorsport.com/Forg...duct--792.html
    FWIW-I've been running Forge 007's since late '01 and changed the o-rings and pistons once in some 65,000 miles of use.
    I've never heard that noise you mentioned then again I'm only a wee Stage-II and not running the boost levels you'll see.
    As stated earlier a yearly re-ube is a real good idea.
    Dec 08 2017
    Chicago
    Ok thanks I'll look into that
    Dec 08 2017
    Chicago
    Here is a sound clip I took from early today hope it helps https://youtu.be/iZ87xf01i0s
    Dec 08 2017
    Chicago
    https://youtu.be/pgF1EmmNrOY
    Dec 08 2017
    Chicago
    I've never had frankenturbos on any of my b5s and I've never heard this sound with my k04s so I'm a little concerned
    Veteran Member Four Rings cu52's Avatar
    Dec 11 2008
    Denver Metro
    Sounds similar to when my DV's were leaking. They were the old 710A and could not hold a vac. Have a MityVac? if so connect it to the DV nipple and see if they hold vacuum, if not rebuild/grease them
    13 Tundra SUPERCHARGED
    01 B5 S4 Avant, C5 RS6, 18 SQ5
    Gone:
    03 RS6, 01 605 Tial Avant, 00 S4, 01 S4 Avant, 01 Imola, 00 Hibiscus, 04 4.2L Allroad 6 speed swap, 03 allroad, 04 Audi Allroad 6MT 2.7T ST3!, 04 Allroad TIP, 02 Allroad MT6 2.7, 08 Toyota Sequoia, 04 Audi S4 MT6, 01 S4 Casablanca White 6MT , 04 VW GTI 5MT, 03 A4 Avant 3.0 6MT, 09 Tundra CM, 11 Tacoma DC, 02 A4 Avant 3.0 Tip, 01.5 S4 Avant tip GIAC stage 3-, 00 S4 6mt
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    Quote Originally Posted by cu52 View Post
    To add you can also push the diaphragm gently and then cap the vac line port with your thumb as a quick check if the diaphragm stays put it's good
    Dec 08 2017
    Chicago
    Ok thank you
