Hey guys, I'm having a hard time finding the g61 knock sensor wiring information on a 06 a4 2.0t . I've had small timing issues and poor power delivery for a long time now. After getting the fuel system right I finally found that the front knock sensor g61 has a wire that's broken right at the connector. There are 3 wires, a red/white/ and black wire. The black one is broken. However the car has no codes for it and the knock sensor test always comes back system ok. But block 26 voltage is different for each cylinder.
I'm trying to figure out the role of each wire on that sensor. Is one a voltage,then shield, then ground? Or are two signal voltage and the black ground? I'm asking because I'll have to take the make connector apart and repin the black wire or solder it back together.
While logging block 20, cyl2 will show values up to -10, and the others only show -3 to -4. I'm guessing the negative values are timing pull? Even under light throttle cruising I will get negative values, but none at idle. If the - values are not pull someone please tell me.
