Results 1 to 22 of 22
    Jun 09 2017
    Signature
    GTA
    S6/S7 Stage 3 (RS7 Turbos) 1/4 Mile Times on 93?
    Does anyone have solid 1/4 times and MPH for stage 3 using 93 octane tune with 93 octane?
    I figure low 11's but really looking to know if 10's are even a possibility on 93 since all the numbers I see from stage 3 guys are on race fuel.. Haven't yet installed my stage 3 kit I've been hoarding, but looking to get a good time on 93 and not sure what that is/means... track opens soon here, will be installing stage 3 and peripherals asap...
    Current Line-Up:
    2008 911 Turbo Cabriolet Manual
    2012 VW Golf R - APR in-house build Stage 4
    2002 Audi TT 225 Quattro Roadster - Big Turbo
    1995 Camaro Z28 6 Speed - Just Bolt-Ons
    Gone: 2015 Audi S6 - Stage 3 / 2015 Audi S4 - Stage 2 / 2012 Subaru Sti Hatch
    Feb 25 2014
    Texas
    I only have dragy times for running 93 octane on the 93 file. Have about 30 runs with my best at 10.73 while averaging 10.8x
    I have actual track times running 104 on 104 file of 10.69 @ 129 followed by separate dragy times running 104 on 104 file of 10.67 @ 131 (130.94). The ET from track to dragy seems spot on while the dragy gives me an extra mph or 2 as compared to the track. This may have been attributed to much better weather conditions during the dragy runs but these cars have shown that a delta in DA (within reason) doesn't change much.
    Regarding ET, I firmly believe running 93 on 93 file will yield 10.7x-10.8x at the track.
    For full transparency, I was running an e22 blend on the 93 file. I have a Zeitronix ECA gauge so my blend is accurate. I put about a gallon of e85 on top of roughly 5-6 gallons of 93.
    Here are some of my better pump gas runs
    Here are a few race gas runs
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Jun 09 2017
    Signature
    GTA
    That is some great info, thanks! Definitely surprised to hear the S6 can do 10's with 93, its exactly what I'm looking to do, just wasn't sure if it was possible without breaking a record or something.. The difference in times from 93 to 104 is smaller than I imagined..
    Current Line-Up:
    Feb 25 2014
    Texas
    Quote Originally Posted by 15 Phantom S6 View Post
    It definitely is...and that seems attributed to APR not being able to get too aggressive with OTS software
    10.65 @ 129mph
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    The best I've done on 93 is 11.4sec, although all of my runs have been in cooler conditions (about 50 degrees) with wheel spin. I also run a zeitronix ethanol analyzer and keep the e content at 22-23. Here in WA I only have 92 octane available, and generally add about 2 gallons of e85 to attain an ethanol content of 23. I believe the car has 10's in it, I just don't get out that much and have minimal experience in getting it to launch properly. Full disclosure, my car is likely a fair bit heavier than others, as I've got additional amplifiers and a heavy subwoofer enclosure, as well as a bunch of sound deadening material installed in the car.
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
    Jan 22 2017
    New York
    As you have found out, traction is king when ET is the goal. I’m fairly certain 10’s are obtainable on pump as well, however I haven’t made any passes on 93 to confirm.
    OlyS6, what was your mph when you ran?
    Jan 22 2017
    New York
    Quote Originally Posted by Ze_Nardo6 View Post
    Those runs look very solid. Nice!
    Feb 25 2014
    Texas
    Quote Originally Posted by OlyS6 View Post
    As you increase power with these cars, the warmer temps become more necessary for quicker ET. I've found 68-80 degrees is optimal for traction at these power levels. In stock form, temps could be much lower. We've also discussed you launching on asphalt compared to my launching on concrete, the latter yielding better traction. Once it warms and you find a better surface, you'll see 10s Andre!
    Quote Originally Posted by low-profile View Post
    Thanks BK!
    10.65 @ 129mph
    Nov 22 2016
    Olympia, WA
    My trap speeds have been ranging from 125-128mph on the runs that I've done.
    Feb 25 2014
    Texas
    If you’re hitting 128 traps on pump gas, your car is capable of 10.7x-10.8x with better conditions
    10.65 @ 129mph
    Nov 22 2016
    Olympia, WA
    Cool! I'll keep trying- as soon as I finish getting the car put back together again...
    Feb 25 2014
    Texas
    You are a mad scientist!
    10.65 @ 129mph
    Jun 09 2017
    Signature
    GTA
    Still looking to know, has anyone hit 10's in a S6 with RS7 turbos on 93 octane yet??
    I haven't seen or heard of anyone hitting 10's unless it's with race gas.. It's winter here and I can only dream of good weather and tack time..
    I was mostly preoccupied with my other rides hitting the track last year but I did try twice to hit the 1/4 mile track with my S6 last fall and one time the track was wet and they only were allowing 1/8th mile runs, and the other time there was an accident that shut the track down for the day prior to my run..
    Anyone?
    Current Line-Up:
    Jan 22 2017
    New York
    ZeNardo posted a couple of draggy runs on 93 tune/octane.
    As far as actual drag track, idk. Myself, the nearest drag strip is 3-4 hours away... so if I’m going, I will be running the best fuel and tune I have.
    Nov 22 2016
    Olympia, WA
    Best dragy run I’ve managed on pump has is 11.2.
    Stage 3 S6.
    Jun 09 2017
    Signature
    GTA
    Looks like 10's on a stage 3 (RS7 turbos) is gonna be a bit harder than I imagined it would be.. ZeNardo's dragy runs gives me hope, I'd love to have a 10 second daily on pump..
    When I did hit the track last year with my S6, I went with race gas to try an get my best time but I've since changed my strategy since we all know 10's is more than doable on race gas..
    If I ever hit 10's on pump, maybe then I'll go for the gusto and see how fast the 104 file nets me..
    Gonna try and max things on pump gas for now and would love to hear from anyone with stage 3 (RS7 Turbos) who has hit a 10 second 1/4 mile run.. I'm easily 3 months away from any track time...
    Current Line-Up:
    Feb 17 2010
    1991 Toyota MR2 Turbo
    Minnesota
    DS1 on E85 stage 3 should easily be 10's. Even stage 2 on E85 for DS1 most likely could hit high 10's.
    2013 Audi S6
    DS1 with Flex Fuel, SRM Custom Tuned
    Turbosystems Stage 1 Turbos
    Turbosystems Actuators
    MercRacing HX
    SRM Inlets
    SRM Driveshaft Carrier
    All Eurocode and 034 Mounts
    Eurocode F&R Sway Bars
    Lightweight 19" Fast Wheels FC04
    Jun 09 2017
    Signature
    GTA
    I agree, for sure 10's on E85, but no E85 around my neck of the woods which is why I'd like to have 10's on what I have in my tank 100% of the time.. Not that it matters, but getting into the 10's was my original inspiration for going stage 3...
    Once more folks are using the DS1, I believe 10's will be a "normal" on 93 octane.. For now, I'd love for an APR tune to do it, and I do believe its possible, but it just seems an uphill battle at this point..
    Current Line-Up:
    Feb 17 2010
    Minnesota
    10's for stage 3 on 93 octane I'd say wouldn't be normal. Maybe with weight reduction and a good tire/wheel setup.
    2013 Audi S6
    MercRacing HX
    SRM Inlets
    Jan 22 2017
    New York
    It’s quite doable Phantom. What did you run on 104? That should give you a good idea of where you stand. Traction is the biggest obstacle for any S6 with street tires. The 93 tune will actually help to attain consistent 60fts. Good luck.
    Jun 09 2017
    Signature
    GTA
    I went to the track with 104 in the tank but the track had issues so I wasn't able to run..
    Going hit the track when it opens up again in the spring and I'm gonna keep going until I'm satisfied that I've hit the best time I can with my current set-up... I do have the belief that 10's is possible on 93 with APR's stage 3 tune, but I realize that just because I have a belief doesn't mean it will happen.. After a few runs I'll know if it is really a possibility or not.
    After I get the best I can run, if I see the stage 3 guys using DS1 and consistently getting some better times over APR, I'll probably make the switch..
    Current Line-Up:
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Quote Originally Posted by Saleen S7 TT View Post
    Its all conjecture but I’d agree that 10’s on APR 93 may be a stretch in DD form. DS1 will probably add more tq compared to the APR stg 3 tune. If it doesn’t get to 10’s initially then its only a matter of time as the tune gets revised more and more.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
