Results 1 to 40 of 55
    Veteran Member Three Rings Nogaro Nitwit's Avatar
    Sep 13 2010
    2000 S4, 2005 allroad 2.7t, 2004 allroad 4.2
    Sterling, VA
    Suspension spacers to use A6 coilovers on the allroad
    I have been working with a fellow allroad enthusiast to get some of these for myself. He developed these and has refined them. There are a few allroaders out there running these currently. Due to some delays with his source for these, I have worked with him to get a new supplier for a limited run. If you have been wanting to go static coilovers without having to touch the subframe spacers, changing the front uprights and lower control arms, these are for you. This is for a set of all 4 made with aluminum billet. These will use the allroad upper hats and use A6 coilovers. These spacers measure 2" and will get you to a proper and usable height. These were developed since there are many more A6 based coilover choices vs the very few allroad choices.
    Currently I have 5 confirmed so far for these through another forum, the Facebook allroad group and Instagram
    Group pricing is currently the following for both front and rear suspension spacers (all 4):
    1-5 orders - $400
    6-8 orders - $375
    9+ orders - $350
    Just let me know the interest.
    2000 S4 - ASP Stage 3, ER ICs, ASP DPs, ASP True Dual Exhaust, 710Ns, Neuspeed 19mm swaybar, ASP phenolic spacers and many more goodies
    2005 allroad 2.7t - 6mt conversion, Daz Stage 2 tune, S6 seats/headliner, Podi boost gauge w/ custom pod, Arnott Gen IIs, H-sport swaybars, Magnaflow exhaust, 19"x9.5" Miro 111's, Euro roof rails, OEM spoiler, LED Tails
    2004 allroad 4.2 - APR tune, OEM spoiler, H-sport swaybars, OEM hitch, BFG K02 all-terrain tires, Yakima roof basket
    Sep 11 2009
    NE
    I am running a set of these. Without these it is not possible to use A6/W8 suspension products on allroad without going to extremes like removing frame spacers and replacing uprights. Far more involved and expensive proposition!
    Sep 13 2010
    Sterling, VA
    Quote Originally Posted by julex View Post
    Thanks for your input, Julex. I knew you were running a version, but did not want to speak for you
    Senior Member Three Rings A6Rick's Avatar
    May 31 2011
    New York
    Please correct me if I'm wrong, but wouldn't it just be easier to just swap the strut top hats? Why are spacers needed?
    Sent from my SM-G955U using Audizine mobile app
    Sep 11 2009
    NE
    Quote Originally Posted by A6Rick View Post
    Spacers are needed because allroad has taller uprights, wheels, wheel wells and most notable longer shocks. The shocks are about 1" longer.
    Strut hats change nothing between A6 and allroad ones. They are pretty much identical when it comes to spacing of top of strut to body mount point on chassis - which is the hat's thickness.
    If you install A6 suspension in allroad without spacers, you'll install 1" shorter shock/spring causing it to drop, but not by 1", but by about 1.5" in front and 2" in back, ending up with wheels well in the fenders and slammed position.
    Why 1.5" front and 2" in back and not 1" though?
    This is because the shock doesn't attach to the wheel itself (if it did then it would be 1") but much closer to the pivot point which is the straight lower arm frame bushing. Front shock attachment point is roughly at a bit more than 1/2 the distance from pivot to wheel hub. Rear is almost exact at 1/2 distance. I have the exact number somewhere because I did a lot of research on this back in days.
    Use you basic trigonometry skills to figure this out .
    Sep 13 2010
    Sterling, VA
    Thanks Julex! Been down sick for the past few days and missed this. Hopefully we can wrap this up soon and get them out to everyone.
    May 31 2011
    New York
    That was very clear and concise. I appreciate the feedback. I wasn't aware of the slight differences in allroad suspension parts. Thanks for the info.
    Just bought a 04 allroad and the bags are blown. Was considering throwing on bilstein shocks with h&r springs that I took off of my 4.2 a6.
    Sent from my SM-G955U using Tapatalk
    Jun 10 2013
    United States
    What is the thickness of these spacers?
    Sep 13 2010
    Sterling, VA
    Quote Originally Posted by glennda5id View Post
    2 inches
    Jun 10 2013
    United States
    When do you need to know by?
    Sep 11 2009
    NE
    BC Coilovers not working out?
    Jun 10 2013
    United States
    One of BC shocks I think is making some noise in the rear which is sort of annoying, but it could be something else. They ride fine and I hardly drive the car these days. That being said, Julex you have me sold on this approach and I am considering getting a pair of spacers just to have on hand if I want to go the route of A6 coilovers. They may just gather dust though...
    Sep 13 2010
    Sterling, VA
    Let me know soon. I will be ending the group buy soon
    Jun 10 2013
    United States
    Julex,
    I run about 10 mm below Level 1. With the 2" spacers, can one get ST Coilovers at Level 1 or close to it?
    Sep 11 2009
    NE
    Julex,
    you should be able to. I have 1.5" spacers in mine but i had to crank the collars way up, especially rear, to sit at that -20mm L1 level. 2" is the sweet spot (because it gives a little more of rubber bump stop into effective range) and I would do that if I was doing it all over again.
    Jun 10 2013
    United States
    Okay, I'll take a set!
    Sep 13 2010
    Sterling, VA
    Cool. I'll add you to the list. I will keep you in the loop for production and payment.
    Sep 13 2010
    Sterling, VA
    I pulled the coilovers last night and will be shipping them off to make sure the spacers are good to go. A test run will be done and once everything checks out, the rest of the run will be created for the group buy.
    Currently we have enough folks committed that we have hit the $350 price point
    Veteran Member Four Rings SteelyS6's Avatar
    Oct 29 2011
    Winnipeg Manitoba
    Nice, folks will be happy with this. Wish I had some more disposable funds right now.
    Sep 13 2010
    Sterling, VA
    Quote Originally Posted by SteelyS6 View Post
    Do it! You know you want to. It will make you feel good. All the cool people are doing it. \peer pressure
    Oct 29 2011
    Winnipeg Manitoba
    Quote Originally Posted by Nogaro Nitwit View Post
    Lol, having two allroads on coilovers might get me burnt alive at the stake! ;)
    Sep 13 2010
    Sterling, VA
    This will be going for another week or two. We reached the $350 price point for all 4 spacers.
    Veteran Member Three Rings das_boosthead's Avatar
    Oct 01 2009
    VA
    Can't wait! Shopping for coilovers now.
    Sep 13 2010
    Sterling, VA
    Just a heads up that production is starting next week. SO get me your info ASAP if I don't already have it
    Sep 13 2010
    Sterling, VA
    The production is about to begin......
    My test run has commenced
    Sep 13 2010
    Sterling, VA
    Just an update on this. Mark at Autospeed Performance is doing the spacers for the group buy. He has sent me some updated photos. The spacers have been produced and will be shipped to me within the next day or so. I can't wait to get these on and try them out. As long as they are a go on my car, the production will start. Looking so good!
    Sep 13 2010
    Sterling, VA
    The day has finally arrived. A package arrived yesterday.....
    Along with the suspension I sent up for test fitting and refinement I received the newly machined spacers
    Front and rear spacers
    The underside of the front suspension spacer
    Unfortunately I did not have time to get things installed last night. But I was able to get a quick test fitting in. Hopefully installed pictures in the next day or so.
    Looks like great quality work by auto speed
    Mar 30 2004
    San Francisco
    Hey Nogaro Nitwit, I would love to see some more pics of your allroads, especially the Maroon one with those BFGs. Im thinking of building my maroon AR into an offroad rig....
    Sep 13 2010
    Sterling, VA
    Quote Originally Posted by pyite20v View Post
    Are you on Instagram at all? That’s about the only social media I do. Plenty of pics of that on my feed. Just look up my user named there.
    Sep 16 2018
    Buffalo
    Hey nogaro nitwit, is there a group buy still going on for these? If so price? Would like to convert before snow starts coming and these are what ive been looking for.
    Sep 13 2010
    Sterling, VA
    Quote Originally Posted by Sgt Audi View Post
    Yes. We have had a few drop out. DM me with your email and mailing address. Payment needed ASAP!! $350 + shipping
    Sep 16 2018
    Buffalo
    Hey I'm new to using forms and want to buy this can you message me or use facebook or something? Thanks willing to buy asap
    Established Member Two Rings Fahrvergnugen's Avatar
    Dec 01 2017
    '03 Allroad yet to be resurrected, '99 VW Cabrio, '99 BMW 323i, '83 VW Pickup, '84 MB 380SEC
    Olathe, CO
    I have an '01 Allroad with the Arnott conversion on the car, an early version I think... The spacer this would replace is rubber. Would this work to replace that?
    Sep 13 2010
    Sterling, VA
    Quote Originally Posted by Fahrvergnugen View Post
    No, this does not replace the rubber on the Arnott coil conversion. This allows for the shorter A6/S6 coilovers to be used on the allroad, which needs longer coilovers due to the subframe spacers
    Sep 16 2018
    Buffalo
    I'm trying to install these today and im looking at the rear spacers now, do I need to purchase a longer bolt to mount to the top with the spacer there? If so what size bolt and thread is needed?
    Sep 16 2018
    Buffalo
    If anyone is looking it is m8 x 1.25 80mm. 75 could work as well
    Active Member One Ring steveneedsmoney's Avatar
    Jul 10 2017
    Wyoming
    Were there any of these left over? Or a CNC file maybe?
    Jan 30 2016
    Central Michigan
    I am looking for a set of these 2" spacers to put on my 2005 allroad 2.7 using ST coil overs and it's too low....
    Any sources to buy more of theses?
    Oct 01 2009
    VA
    Quote Originally Posted by sswilliams66 View Post
    Check with Nogaro Nitwit. You may also consider reaching out to Mark at Autospeed who handled the original batch.
