So a few months ago I upgraded my brakes:
- switched out OEM calipers with a set of Bren I calipers from the 3.0TQ5
- JHM LW rotors all 4 corners
- JHM ss brake lines
- hawk pads (rear) red stuff (fronts)
After all this, the braking was responsive, but my pedal is softer than used to be. I did 2 full flushes and an abs cycle to ensure air in lines was not the issue. Still same soft feel. Then took the car to Audi to have them flush and cycle ABS. Still same soft feel.
What in the heck am I missing?
I know the pedal feel could be stiffer. I know this bc if I pump the brake once and then brake, braking is much more stiff.
What else do you guys think I am missing to make the pedal not as soft?
Here’s a before/ after pic because, well pics are more fun
