Results 1 to 9 of 9
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    B5 S4 w/ 8v A3 Steering Wheel - Possible to get Buttons to Work? Aftermarket Headunit
    Hello,
    I've spent some time trying to get my RNS-E fully integrated into my B5, but the lack of support now days has me rethinking my decision.
    I've been trying to get my steering wheel buttons to work and I'm not sure it'll ever happen (trying on 2010+ RNS-E with 8v A3 SW). Theres a few other things that don't work like OEM, and its driving me crazy.
    Lately the thought has crossed my mind to ditch the OEM RNS-e and dive into the world of aftermarket head units. I really like the idea of bluetooth music and smartphone integration, Just really wish I could keep the looks of the RNS-e.
    Does anyone know if this is possible to get the buttons to work on an aftermarket head unit? So far the Pioneer App radio 4 and NEX units have caught my eye.
    Do any headunits like to communicate better with the audi steering wheels? as that would be a big factor in my decision.
    Another question I have, have any of the new radios been able to send track and Nav info to the cluster?
    Below is a picture of my wheel and current RNS-e setup
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Veteran Member Three Rings HUFset's Avatar
    May 08 2014
    B5 A4 GTRS, MK4 Jetta F21T
    CLFX, Denver
    You have the wrong buttons, need the correct SCM(from 8V A3) and in theory a PAC unit between SCM and Head Unit. I’ve collected all the audi parts. But still haven’t hooked it all up yet. I also think that you need to wire in a CAN Gateway in order to get push to talk and a bluetooth module working. I don’t think the aftermarket HU allows you to cut any corners since you need the extra PAC unit.
    2000 A4 1.8TQM|GTRS Elim|550cc Maestro|034 AEM WMI|ECS RA4|Carbonio CAI|034/Borla TBE|CTS FMIC|2.0T/AWP harness|Toy Guy/JHM duo SS|034 mounts|034 CAs/Links|ST Coilovers|A6 Strut Brace|ECS RDiff Mount|Apikol Rear Diff Bushings|A4 Sport Cloths|Euro S3 FBMFSW|B6 S4 Rearview|Euro Bolster|All S4 Interior/Exterior Bits|Sport Mirrors/Trim|M3 Spoiler|Aero Arm Wipers|OEM Votex Rack and A4 Bra|A8 Fat Fives|S4 Cluster|P3 VIDI Gauge|Pioneer AVH-X4700BS|Alpine PDX-V9|6 Polk DB Mids|Eclipse 12"
    Oct 27 2014
    Flag/Phx, AZ
    Quote Originally Posted by HUFset View Post
    Hm, so it wouldnt be as simple as hooking up an aftermarket steering wheel control adapter? Such as:
    https://www.crutchfield.com/p_541SWI...BoC4JMQAvD_BwE
    IG: CJ_s4
    May 08 2014
    CLFX, Denver
    In addition to everything else. The HU needs to be able to read CAN signal coming from steering wheel and SCM.
    Oct 27 2014
    Flag/Phx, AZ
    I see, so the steering control adapters read can signals, not the actual button presses. What exactly is a PAC unit?
    IG: CJ_s4
    May 08 2014
    CLFX, Denver
    The steering wheel sends LIN or CAN signals to the radio. The B5 radio is k line so none of that communicates. By adding an aftermarket HU you will need that PAC unit for it to understand those signals. You are adding two steps to getting your wheel to fully work.The only person I know that has an RNSE and steering wheel working is DolphinV8 and he wants to sell the instructions. That other thread we are in is close to solving it. I think It actually is solved just need to add that PAC unit and wire it all up.
    Oct 27 2014
    Flag/Phx, AZ
    What SCM do you have or have tried?
    Looks like if I have any chance of getting the buttons to work on this steering wheel, I'll need an SCM that will accept LIN 2.0 signals. I found this on ross techs website:
    http://wiki.ross-tech.com/wiki/index...odule_Versions
    On a side note, I just bought some stuff to start bench testing the whole setup and I'm going to use an Arduino with a CANBUS shield to see if I can simulate MFSW commands to the RNS-E.
    IG: CJ_s4
    May 08 2014
    CLFX, Denver
    I have two different SCMs in theory to support both types of buttons. You are definitely on the correct path with that document. I pulled a few last summer from junkyards using that document. The only issue I’m have is wiring them up.
    Oct 27 2014
    Flag/Phx, AZ
    After some more research, It looks like it should be no issue to get the 8v (highline buttons with '< >') out to the steering control module. But the RNSE might not recognize these CAN signals converted from the LIN 2.0.
    There may be hope in aftermarket radios by using a PAC unit as mentioned above.
    Im still determined to get the RNS-E working. As a bonus, I would really love to use the other buttons to control my Color MFA that I have coming in. This will be part of my bench prototype
    IG: CJ_s4
