Results 1 to 9 of 9
    Audi S8 D4 Center Resonator delete real gains?!
    I on the precipice of doing it and would appreciate feedback from folk who did it,
    With that said,
    I got APR Stage II already done and stock rest of exhaust with Center Resonator still in place!!
    Using Tapatalk
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by soooma View Post
    With that said,
    Doubtful. I don't have a 4.0T engine, but if it is a true reso. it has a straight through pipe in the center. Such resos just tune sound by absorbing unpleasant frequencies. Every performance car I've ever owned with resos just sounded really bad if removed and made no greater power.
    When installing big downpipes, especially catless, I had to add a reso to tame that drone and raspiness, and lost no power by doing so.
    Your car may be different, but true resos are not mufflers and should have no impact on power.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Quote Originally Posted by MSq5 View Post
    My bad,
    I should have clarified that I was talking about SOUND GAINS rather than power gains!
    Thanks
    Using Tapatalk
    Junior Member One Ring
    Apr 03 2018
    Costa Mesa/CA
    For what it's worth, I did it on my S6 and it was the best $250 I've ever spent. The sound is incredible, no drone, sounds menacing when you're foot's in it and can be relatively quiet when in comfort mode. I get alot of compliments on how the car sounds. In my opinion, it's a (mild) hybrid of a Camaro mixed with a Gallardo, muscley & exotic at the same time.
    BTW, very jealous of the S8 !!!!
    Apr 02 2018
    Muskegon, MI
    Quote Originally Posted by S4S6JGC View Post
    Would you suggest losing the center muffs/resonators or the rear mufflers?
    Thank you,
    Here are some pictures after RS7 wheels,
    Using Tapatalk
    Apr 03 2018
    Costa Mesa/CA
    Quote Originally Posted by Gilly44 View Post
    Atleast on my car, I just replaced the center resonator (closest to the mufflers) with an X-pipe.
    Why X or H pipe?!
    How does it hurt to have straight pipes?!
    Using Tapatalk
    Mar 08 2017
    VA
    The s8 already has an x pipe...I have an since plus and when I removed the center resonator the sound only increases slightly... But what actually changes are the crackles and pops... You get now of it and sounds pretty good.
    However it's not loud...I even got catless dps and it still isn't loud enough when I want it to be loud. I don't want to be obnoxious but sometimes wish I would have gotten the sports exhaust.
