Originally Posted by
Rodizzle
Measuring ethanol with the sensor very easy, fill up couple gallons of a e85 and some of the 91 , check your gauge or whatever device you decide to go with. I personally went with flueit ( Bluetooth link to ur phone ) and yes you’ll need a HPFP to run the e40 file . And 034 installed my PLM . Labor wasn’t much like 300 or something . There’s a good shop in Santa Clara that I recently tried out with extremely competitive prices not to mention good customer service. Dubclinic the owner is Bernard
Yea I know Bernard he's the man I'll probably never take my car anywhere else. But for $300 at 034 I'd probably do it there so that they can flash the car at the same time.
1- From this thread below Chris@EPL is stating dampened pulley are the most reliable and if I understood correctly Fluidampr is the way to go for those.
How many have switched their OEM Pulleys to dampened Pulleys?
2-How do you guys calculate ratio?
For instance the SC pulley I have from 034 is 57.70mm
And say I was to go with JHM 187 how would I calculate the ratio and how do you determine whether that ratio is good or bad
Sent from my iPhone using
Audizine
