Results 1 to 20 of 20
Thread: KW V1
    Senior Member Two Rings Skeee's Avatar
    Nov 19 2008
    2008 Audi RS4, 1998 Gti VRT, 2003 Audi RS6, 2004 VW R32
    Washington
    KW V1
    So my DRC finally decided to take a dump. Current Setup is DRC with H&R Springs. Looking at KW V1 as an alternative. I know most of you run a V3's but this is for a non daily driven car and most likely a weekend car with no track purpose. Anyone has experience with them on a B7 RS4 platform? I've ran H&R, Stasis, Bilstein and ST, and Konis and KW on my previous cars and by far, I think Konis are the most comfortable setup I've had on my old B6 A4..
    Dirtbag
    Dec 09 2016
    Charlotte NC
    Look into scale suspension, that's what I have really good customer service, price is very fair and I am very happy with them
    2008 black rs4
    2001 nardo miata
    Charlotte, NC
    Nov 25 2011
    2018 F80 M3 ZCP, 2007 RS4
    I had the STs on my B7 A4 and they rode well but were too bouncy. Especially on a car like the RS4 the KW V1s will probably be a downgrade. Theyre essentially the same as the STs from what I know.
    I have the Bilstein PSS9 on my RS and they are amazing. Super smooth and very planted. Ive had many complements from my friends who competitively track their cars about how balanced they feel. Comfy yet handle amazing. I recommend the PSS9s
    Established Member Two Rings seblove's Avatar
    Feb 28 2013
    los angeles, ca
    I've had a ride on v1s in a b5 s4. Rode like absolute shit, only good for going straight imo. I'd highly recommend shelling out for the v3s if you want to maintain the ride quality.
    2008 RS4 Satin Pearl wrap - JHM stg 1+ blower - full JHM exhaust, resonated & catless - JHM LWFW & 3R clutch - PSS9s + 034 control arms & sways - JHM short shift + linkage - Apikol Rear Diff Mount - Stern Motor Mounts - 034 Snub Mount - 034 Trans Mount - JHM IM spacers
    Oct 11 2007
    Suburbia
    Do you know what revision your DRC was at before it started leaking? I was on rev C with an H&R setup like yourself and daily drove, accruing over 75K miles on DRC+H&R with no signs of failing when I sold.
    I loved the DRC setup, worked great!
    12' R8 Daytona/CF V10 6MT
    07' RS4 Daytona/Panda
    Veteran Member Three Rings 993140's Avatar
    Oct 14 2012
    GT3 Touring
    Way Out West
    Quote Originally Posted by seblove View Post
    I don't know about the V1's but I have the V3's and I feel that set is just perfect for the RS4. Slightly firmer than DRC but perfectly acceptable ride.
    Viken
    2024 RS3
    2023 S3 Premium Plus
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    pss9.
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
    Nov 19 2008
    Washington
    I end up getting a set of V3's. got a killer deal on a brand new set from a good friends at Fifteen52.
    Dirtbag
    Veteran Member Three Rings my_RS4's Avatar
    Apr 15 2016
    Beach Cruiser
    Venice
    Quote Originally Posted by Skeee View Post
    Nice man. Update this thread with your thoughts on them when you get them all dialed in.
    IG @myRS4 | 2007 RS4 | Phantom Black | Ti Converted | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed + Citied + CC'd | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | JHM Lighweight Flywheeled | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    That’s awesome. You’ll like the v3’s a lot.
    Senior Member Two Rings SQ RS4's Avatar
    Feb 02 2015
    2008AudiRS4 2016AudiS6 2009NissanGTR 2016HondaPilot
    Clarksburg, MD
    Be sure to post up a review or some feedback once you have put some miles on them.
    Also, mind sharing what you paid for them? PM is fine too.
    Nov 19 2008
    Washington
    Quote Originally Posted by SQ RS4 View Post
    I think the price i paid is for a homie hookup. lets just say, it was too good of a price to pass up. Considered paying for a lower version for a V3 setup..if you know what i mean.
    Dirtbag
    Nov 19 2008
    Washington
    will do
    Dirtbag
    Dec 05 2006
    So. Cal.
    Can we ask why you paid? PM if you don't want to put it out there.
    Nov 19 2008
    Washington
    your PM box is full
    Dirtbag
    Dec 05 2006
    So. Cal.
    I'll empty it. Thanks for letting me know
    Nov 19 2008
    Washington
    My appointment is on the 14th of this month. Ill let you guys know my thoughts on them once its installed.
    Dirtbag
    Nov 19 2008
    Washington
    UPDATE: Coilovers went in yesterday.. Shop took a little while but they were able to dialed it in to the ride height that I wanted. My first initial impression is the car feels near identical to OEM but more firm and rode quite nice. They have worked with numerous RS before using the same setup and they recommended to adjust the factory settings to +1 on dampening.
    Dirtbag
    Junior Member Two Rings
    Nov 06 2015
    Campbell/CA/USA
    Quote Originally Posted by Keithpul View Post
    What are the spring rates of your scale suspension? Did you do the air cup up front?
    Edit - Found it on their site.
    Front Spring Rate (kgf/mm) 11kg (Default)
    Rear Spring Rate (kgf/mm) 9kg (Default)
    Suspension Type Front Double Wishbone
    Suspension Type Rear Multilink
    Number of Valving Selections 12
    Aluminium Type 6061-T6 CNC-Forged
    Spring Color (Default) Black Gloss
    Powdercoated Body Black Gloss
    Anodized Body Black
    Adjustable End Links Included No
    Body Diameter (mm) M52X1.5
    Internal Design Monotube
    Shock Oil Type Synthetic Shock Oil
    Pressurized Charge High Pressure Nitrogen gas
    Welding Required No
    Low Version Available? Yes
    Extreme Low Available ? No
    Rebuildable Yes
    Warranty 2 Years
    Nov 19 2008
    Washington
    I'm not sure what is the spring rates on these
    Dirtbag
