90 ft lbs is what I use and as mentioned above, I recheck the torque after a bit of driving (same or next day). And as a PSA, if you're running aftermarket wheels with conical bolt seats, be sure to keep a set of 5 of the OEM ball-seat lugs in your trunk in order to attach your spare wheel/tire in case you get a flat. Do not use conical seat bolts to attach the spare wheel - it requires ball seat lugs!
