Results 1 to 9 of 9
    Established Member Two Rings mercedesinfarct's Avatar
    Jun 13 2017
    Philadelphia
    Installing Deval lip without removing front bumper
    Has anyone successfully installed this lip or something similar without removing the front cover? Directions recommend removal, just trying to see if it's possible. Thanks
    Veteran Member Four Rings Rodizzle's Avatar
    Jun 17 2015
    Bayarea
    Quote Originally Posted by mercedesinfarct View Post
    I installed my ECS lip without removing my bumper . I assume it’s a Similar application.
    Established Member Two Rings RCFC89's Avatar
    Jan 28 2017
    I'm having a body shop do mine. I guess you could always use self tapping screws rather then the nut/bolt approach Deval recommends. I did the rear ECS piece without taking off the rear bumper but ended up still having to take it off because like all ECS products the fitment was shit and I had to have the clips customized to achieve a better fit.
    2015 Nogaro Blue S4 (Prestige/Black Optics/Audi Exclusive Interior)
    Jun 13 2017
    Philadelphia
    Yeah.. Just seems a waste to have a shop do such a simple job.. Their reasoning for removing the bumper is for best fitment, but theoretically you could achieve best fitment without removing the front cover
    Sent from my ONEPLUS A3000 using Audizine mobile app
    Jan 28 2017
    Its your car. Do whatever you want.
    Jun 13 2017
    Philadelphia
    Quote Originally Posted by RCFC89 View Post
    Thanks for that...
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    If its a B8, the deval lip replaces the chrome middle lip. The chrome middle lip has 3 or 4 bolts that are difficult to get to without removing the bumper. It is possible, but you would need to remove the lower trays, both of them and then get some extension magic going to pull those bolts off.
    Hence, why people generally install it while the bumper is off the car. I have the lip for the b8 and I havent done it yet because i want to get it wrapped, but I will be pulling the bumper to install it this summer.
    Garage:
    04 996TT X50, 06 Boxster S, 88 911 Targa, 16 S3
    Jan 28 2017
    Did you install it without removing front bumper? How did it go?
    Jun 16 2011
    996tt
    MA
    Never got around to it. I need to pull the bumper to redo the vinyl on the crash support... so...
    Garage:
