Results 1 to 3 of 3
    Jul 14 2009
    Pasadena
    Meyle HD front sway bar end links
    For sale:
    used meyle HD front sway bar end links.
    If you car has a clunk/creaking when turning the wheels this is the likely cause. Really makes a big difference when there is a fresh set.
    These were installed for 1,000 miles and then removed for the more aggressive 034 solid ones. They are however perfect and just dirty.
    "The end links keep the sway bar connected to the suspension on either side, allowing the torsion made from one end to be transferred for better stability. If the end links, or their bushings, have failed or become damaged, the setup will allow for too much movement of the sway bar, giving you a slopping feel through your steering wheel, as well as clunks or knocks in the suspension. Replace your end links to restore proper suspension characteristics."
    List Date: 5/7/2018
    For more info, click here to view the original listing: Meyle HD front sway bar end links
    On Sale For: $20.00
    IG: @matthewee
    Junior Member Two Rings bigbean17's Avatar
    Mar 05 2009
    Silver B6 S4
    MD
    Just bought these using panjo! Thanks, Ryan
    Silver B6 S4: JHM Tune, FI 2.5" Downpipes, FI 2.5" Catback, JHM LW Flywheel, JHM Stage 3 Clutch, JHM SS, 034 Motor Mounts, B5 Perches, VMR 18" RS4 Reps
    Jul 14 2009
    Pasadena
    sold
    IG: @matthewee
