Results 1 to 6 of 6
    May 19 2016
    Wethersfield, CT
    Normal delta in IATs between air intake temp and charge air temp with APR CPS
    Howdy,
    I recently installed an APR CPS and I'm trying to determine what is an expected delta between measured intake air temp and charge air temp.
    Currently, I'm seeing intake air temp roughly 10 degrees F higher than ambient air temp, with charge air temp showing up 10 degrees F warmer than intake air temp.. So bottom line is my charge air temp is 20 degrees hotter than the ambient air temp.
    Is this normal or does it appear the CPS has air trapped in it decreasing effectiveness?
    Thanks in advance,
    E
    Veteran Member Four Rings Dutch_A6's Avatar
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    I just had the CPS installed on mine as well, still haven't had a chance to get into the VCDS and log anything yet, it's either been to wet or to hot.
    Black 2012 A7 Prestige
    Zito ZF01 wheels
    EPL stage 2 tune
    Tinted marker lights
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    May 19 2016
    Wethersfield, CT
    Thanks Dutch, I've been bleeding my coolant system continually and haven't seen much difference.
    Sent from my Pixel 2 using Tapatalk
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    Quote Originally Posted by ESSMAN View Post
    Was able to do some data logging, went from 20mph to redline in 4th 4x and the IAT topped out at 62.75C. only thing is I don't have baseline from the stock heat exchanger to compare it too. I just know I was running it hard and it kept it in check, temps dropped real quickly after each run too.
    Sent from my Pixel XL using Tapatalk
    Zito ZF01 wheels
    EPL stage 2 tune
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    Checkout APR's website they have a graph that shows IAT for stock and CPS.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by Dutch_A6 View Post
    Ok, what was you IAT when you started the pull? What was ambient?
