Hi
Looking to see if I can get any advise on improving low down torque on an S4 B5.
There is pretty much nothing from the engine until I hit around 2500rpm, then it picks up well.
Not really sure where to start, so looking for ideas I can follow up on and try out.
The car is a homebrew done on the cheap, has K04's, 5Bar Apr, 550CC injectors, HP fuel pump, boosting at 25psi, but less than 0psi till around the 2500rpm.
Does have a stage 3 ECU I believe (but not sure) and a larger 85mm MAF with race N75.
Exhaust is 3inch decatted downpipes with 3inch straight through pipe to aftermarket muffler.
Things I want/still need to do (engine wise) is the ICM delete and uprated intercoolers.
(Not sure is these would help much, get a few missfires but always low single digits, and still no power even when cold, so no intercooler heat soak.)
Don't get me wrong the car flys, but just nothing down low.
Any suggestions I can try out gratefully received.
Thanks
