Before you possibly ask, yes; (almost) brand new 2.0 coilpacks paired with BKR7EIX Iridium plugs. With those are a stage 1+ from Motoza and Bosch 550cc injectors.
So driving normally is fine (besides the much needed motor mounts) except when I go 70% to 100% throttle after 3000rpms, the car starts jerking. Sometimes I can even hear backfiring when this happens.
When this happens badly, the engine light will start blinking but then go away when I drive normal again. Isn't the blinking light for bad coil packs?
I just need some Ideas. If the coil packs are bad, then why would it drive like normal again? I feel like it may be blowing out the spark. That's the only Idea I have, so any other input is greatly appreciated.
Thanks,
-Ryan
